20 Most Recent Sony DVP-NS715P DVD Player Questions & Answers
3answers
Sony DVD player reads no disc after inserting disc?
Its due to faulty Laser Lens/head. Try cleaning it by cleaning CD. If still the problem persists, contact near by service center.
6/4/2019 3:27:21 AM • Sony DVP-NS715P... • Answered on Jun 04, 2019
manual
3answers
Readout says, "no disc"
PROB UR LASER NEEDS TO BE REPLACE
12/9/2011 12:15:27 PM • Sony DVP-NS715P... • Answered on Dec 09, 2011
Big Honking Black Box On Screen When I Insert DVD To Play
I fixed the problem by not subscribing as wasting my money. I went to the library instead.
7/22/2011 1:08:39 AM • Sony DVP-NS715P... • Answered on Jul 22, 2011
Will not play DVD, makes rubbing noise when DVD
If it has a paper label on it That can cause the rubbing sound. Is it only this one DVD or will non play? Try using a cleaning disk to remove mess from the laser eye, as well as cleaning this problem disk with a suitable disk cleaning kit
remove any paper labels if it is possible
Please rate my help++++Thanks for uisng FIXYA
6/11/2010 2:34:33 PM • Sony DVP-NS715P... • Answered on Jun 11, 2010
Sony DVP-NS55P dvd player i am having trouble with
Your optical lens needs a tune up or it has reached its maximum shooting power. Send ur unit for tune up, if still same then its time for a new lens.
1/18/2010 11:59:35 AM • Sony DVP-NS715P... • Answered on Jan 18, 2010
2answers
Can not play disc
You can try a lens cleaning kit. If it is the kind that comes as a disc all it will do is lightly brush the lens which may not remove all the debris. If you disassemble the player you can easily get to the laser lens. It will usually be fairly accessible once you remove the DVD case. Sometimes it may be located within another box that needs to be disassembled before you can gain access to the laser. The laser unit will be located on a rail system and will have a small clear lens about the diameter of the eraser on a pencil. You can gently clean it with a cotton swab and lens cleaner or rubbing alcohol works just as well. Try that first before buying the lens cleaning kit or replacing the player.
1/7/2010 1:47:51 AM • Sony DVP-NS715P... • Answered on Jan 07, 2010
Where is the ir senser on a dvp725d
It should be in the dark plastic area. Shine a flashlight in there and look for the IR receiver. You should see it easily. Otherwise, take the remote and get a piece of card board and cover the entire plastic area. Then start aiming the remote and clicking it to do something it can do. When the IR receiver is uncovered it will do something. Remember the area and shine the falshlight in there and you will see it.
4/10/2009 4:31:30 PM • Sony DVP-NS715P... • Answered on Apr 10, 2009
Locked Disc Tray
This is one of those fixes that makes you feel really stupid. We called Best Buy (where we purchased the system) and they told us to unplug the DVD player and plug it back in again. It worked! Duh!
7/2/2008 10:27:42 PM • Sony DVP-NS715P... • Answered on Jul 02, 2008
Sony Dax HDZ235 DVd player
the circuits might be fried. you may need to replace the player. sorry
wg
6/6/2008 2:27:31 PM • Sony DVP-NS715P... • Answered on Jun 06, 2008
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony older model with side speakers flashes red led after blinking green here a grinding sound when powering on
All questions need 'make model (what is is)' as first 3 words in every question please. Television? Stereo? Sound bar? ICE? The grinding noise makes me think you have a cooling fan issue, in which case the flashing LED would be signaling an overheat situation. You can Google sony model blink codes ..
3/18/2024 7:02:45 PM • Sony Televison &... • Answered on Mar 18, 2024
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
3/7/2024 2:17:41 PM • Sony Televison &... • Answered on Mar 07, 2024
Sony DVP-NS715P DVD Player Logo
Popular Tags
16 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
will not play dvd makes rubbing noise
  • Televison & Video
