20 Most Recent True TBB-2 Beverage Cooler Questions & Answers
Temperature stays at 60 doesn't change even when adjusting thermalstat
Inside cooling coil frosted up? turn to run inside fan only until melted away & restart. Possible reasons for this a)dirty condenser down at the compressor which could be brushed but DON'T bend the fins. b0 refrigerant leaked out thru a existing crack. c)poor compressor pumping ability. d) excessive load of warm air entering the cabinet so the system can not reach the request temperature & shut off the compressor to allow that frost to defrost off the evaporator(inside fins) or the system does get too cold & then frosted to the point & never shuts the compressor off so it can defrost.
12/12/2013 10:45:50 PM • True TBB-2... • Answered on Dec 12, 2013
manual
0answers
True back bar unit- Very old, Compressor fan
I agree. start there before investigating further.
1/15/2011 3:21:17 AM • True TBB-2... • Answered on Jan 15, 2011
0answers
If the dial is labled 0-9 what nimber is the
0 is warmwst,9 is the coldest.set it at +2C so that wine/beer dont freeze.beer is best served at 2c.
12/31/2010 6:34:14 PM • True TBB-2... • Answered on Dec 31, 2010
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
1/8/2010 4:11:12 AM • True TBB-2... • Answered on Jan 08, 2010
True TBB-2 Cooler issue
BY to I take it yu mean top area inside cooler. If that is the case and yu are sure the drain is clear it could possibly be one of the following.
1: rusted/ corrodid evaporator drain pan
2: coil in cooler partially frozen
9/23/2009 3:08:27 AM • True TBB-2... • Answered on Sep 23, 2009
I can't get the fluorescent tube to light up when the doors open.
Most fluorescent lighting have ballast in them it more then likely just needs replaced. I have included a how it works link for you HERE
I hope this helps you fix your beverage cooler.
8/15/2008 1:52:35 PM • True TBB-2... • Answered on Aug 15, 2008
True GDM-35EM - 39.5" Glass Door Reach In Refrigerator. I need copy of wiring diagram for a True GDM-35EM please.
Question edited for clarity. The Service Manual says that the wiring diagram is hidden in various parts of the unit. https://www.manualslib.com/manual/1177583/True-Gdm-Series.html?page=43&term=wiring+diagram&selected=1#manual It doesn't appear to be all in one place, but you could contact their Customer Service, or Technical Service Department? https://www.google.com/search?q=true+gdm-35em+wiring+diagram ..
3/1/2023 8:17:39 PM • True... • Answered on Mar 01, 2023
True TBB-2 Beverage Cooler Logo
21 questions posted
Top True Refrigerators Experts
ZJ Limited
ZJ Limited
Ngoro
Are you a True Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
True Refrigerators
  • True Refrigerators
Most Popular Question
temperature stays 60 doesnt change even
  • Refrigerators
