20 Most Recent
Apple Ipod Touch 4 Questions & Answers
I have a iPod 4thgen version 6.16 sincethelast update I have been unable to load it's very slow when selecting my level starts to load then goes blank back to my home screen how do I fix this
try going into settings and rolling back the update for if this does not work connect to a computer using the usb cable and going into the settings of this device through your computer this device after done loading should appear in the pc screen where your devices are shown and is it doing this when you click on a folder or song? also make sure you have anything (songs,pics,etc)on the device if have done a factory reset it may have deleted everything you had downloaded to the device and you may have to start all over.but your best bet it to roll back the updates keep in mind not all updates mean better sometimes they are not checked thoroughly before being put out.if you have a windows pc you may need to download apple software to properly use these files if you just sent these files off a windows os to the mac device it may be doing this because the file types are not agreeable http://www.apple.com/itunes/?cid=OAS-US-DOMAINS-itunes.com try this software when downloading your music,video,etc to your ipod to see if this is even an update problem i hope this helped you out have a good new year.
CAN YOU UNLOCK IPOD ?
unlock as in unlock for any carrier then no if you have disabled then yes you will have to restore the ipod touch by connecting it to itunes
Power button repair
It you really really have press down on it that hard to make it sleep than chances are you won't be able to fix it cheap if you are fully up to date you can go to settings, general, then accessibility then scroll down to the bottom and toggle assistive touch on with this enabled you can turn down the volume of your iPod, make it go to home, make it sleep and other stuff
Forgot my password for my ipod touch
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Flashing screen ipod
To return to normal screen, try tapping twice on the screen with three fingers at the same time.Uninstall the game by holding a finger on it for a couple of secondds til it starts to wiggle. Then press the " x " and delete the game. Try reinstalling again. If it persists, its probably the game.
Its on voice over and i cant do anything
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Shsh blobs prob
ehh.. in example, if you use redsn0w, just connect iPod to your computer, open redsn0w program and choose just boot. I suggest you to download untether...
Forgot my i pod password
My jailbroken ipod wont turn on
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
How do you upload pictures from ipod into computer
The charger on the Ipod should have the USB attachment on other end. It's been a while for me but I believe your computer will (or open the new hardware) auto start you into the process of downloading Apple program. Also, my IPad (same cords) you can buy a card reader. I am wondering now if it is capable of reversing the process to add pics to reader from IPad? Can it be used on Ipod? If so, thenyou could just use the memory card. Anybody know?
