20 Most Recent Sony KV-36FV26 TV Questions & Answers
My JVC HD-56FC97 won't turn on.the power and lamp indicator flash alternately. i just replaced the bulb but that didn't help.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
12/21/2013 9:28:06 AM • Sony KV-36FV26... • Answered on Dec 21, 2013
manual
I need the ref of this flyback transformer
Download the service manual to your Sony model tv. It will have all details.
5/23/2012 4:04:35 AM • Sony KV-36FV26... • Answered on May 23, 2012
2answers
I have a Sony model KDF-e55a20. I just changed the
Sir reset the lamp timer of your unit.
1 Press "Display" on the remote, followed by the 5 button, then the sound up key, and "power on". Do this while the tv is in stand by mode.
2 Then press "jump" 3 times to enter DE service menu.The tv screen will display the total lamp time hours.
3 Reset the the lamp time by pressing channel 3, then mute, then enter.This will return lamp timer back to 0. Hope this may help good day and best regards.
8/18/2011 7:40:08 PM • Sony KV-36FV26... • Answered on Aug 18, 2011
Sony tv par usb main song kon see file par cahlay
USB devices cannot be connected to this TV. If you have a iPod or similar device, you can connect it using the AV output with a "3.5mm-to-yellow/white/red" analog composite cable to connect it to one of the TVs inputs.
Hope I helped...
12/27/2010 5:20:49 AM • Sony KV-36FV26... • Answered on Dec 27, 2010
Can i connect my hp pavillion dv6
No You cannot directly connect the PC to the TV unless there is a convertor pin from the external monitor out for the video and the earphone socket to the audio in( balance the output with an resistive network connected from the headphone pin to the RCA pin)
9/13/2010 7:20:23 AM • Sony KV-36FV26... • Answered on Sep 13, 2010
I have a Sony Tv, Model KV-36FV26 that the cable
those tuners won't cost u much.According to my knowledge they may cost around a 50$-60$ max.
8/29/2010 12:49:09 PM • Sony KV-36FV26... • Answered on Aug 29, 2010
2answers
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
6/24/2010 12:53:03 AM • Sony KV-36FV26... • Answered on Jun 24, 2010
I replaced the lamp of
Hi.
Try first going through color balancing setup and replacing the connection cables at the back.
If colors are still poor and picture quality is bad, then parts that must be checked are color wheel, optical group ( light engine ), and video processing circuits, like white balance etc.
If light is poor, then the ballast board powering the lamp must also be tested.
At that point you may need a technician working at the unit, unless you want to risk replacing the colour wheel without testing the rest.
Several Sony models have been recalled because of light engine factory defect. Give Sony a call telling details on the fault, depending on the model, if problem is light engine , you can get the TV fixed by Sony for free.
You find Sony number on the owners manual.
Regards.
10/27/2009 1:55:04 PM • Sony KV-36FV26... • Answered on Oct 27, 2009
KV-36FV26 service mode entry
Try Display, Channel 5, Volume +, Power On in quick succession
7/2/2009 6:10:57 AM • Sony KV-36FV26... • Answered on Jul 02, 2009
Wrong model showed up on my question - need new reply about part
ORDERED SONY PROJECTION REPLACEMENT LAMP - SHOULD ARRIVE IN ONE MORE DAY - KEEPING FINGERS XXX'D THAT THIS WILL RESOLVE THE PROBLEM - BUT THE TECH WAS EXCELLENT RESOURCE! I'M CONFIDENT IT WILL FIX THE PROBLEM AND THRILLED WE CAN DO IT OURSELVES AND SAVE $200! THANKS !
5/19/2009 7:38:42 PM • Sony KV-36FV26... • Answered on May 19, 2009
2answers
Wrong model number listed in my original question
I gave you exact and correct lamp part number of KDF-E55A20 and explained in previous reply that there is no difference between XL-2200 and XL-2200U lamp. both are same, first on came with new TV and second one is its replacement number.
KV-36FV26 is CRT TV and has no lamp inside.
5/18/2009 9:55:59 PM • Sony KV-36FV26... • Answered on May 18, 2009
Sevice Codes for Sony Wega KV-36FV26 TV
Sony Blinking Codes
http://www.iwaynet.net/~nesda/SonyBlink.html
8/28/2008 6:03:32 PM • Sony KV-36FV26... • Answered on Aug 28, 2008
Power
yes you have defective horizontal output! that is from the power section near at the flyback!
12/9/2007 3:20:43 PM • Sony KV-36FV26... • Answered on Dec 09, 2007
Sony KV-36FV26 TV Logo
23 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony model kdf e55a20 just changed
  • Televison & Video
