20 Most Recent
Sony KV-27V36 27" TV Questions & Answers
I need the user maual
Hello
What do you want? User manual for Sony kv-27v36; or service manual for kv-es34m80? Clear your post please.
OK.
Sony KV-27V36/ No Picture
could be just a fuse or then again if its a plasma the light could be out either way to avoid getting shocked see a tech
Sony TV 27" KV-27V36
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician.
i cannot tell you the cost to fix your tv coz my location is in the Philippines.
Sony KV-27V36 27"
sounds like you got a vertical foldover and could possibly be the vertical output IC but most likly its one of the waveshaper capacitors. This repair is one that alot of repair peeps swap out caps one by one to find the defective one and some use a cap checker but the right way is to use a scope to see the waveform aplitude and the shape of the waveform. This is not a user repair as this set will get repaired down to the componet level as np boards toreplace except for the sound. Take into the shop if you dont mind spending an average of 75 to 125 bucks for this repair
Good luck
SONY KV-27v36
this problem would be in your power spply or the sweep derived power supply. probably a bad capacitor or regulator IC/transistor. Unless you know how to trouble shoot electronics them please have this set looked at by a pro. Good Luck
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
