20 Most Recent
Sony KV-32FS10 32" TV Questions & Answers
Im not sure how to hook the converter box up to it
For a digital to analog converter box, connect your antenna cable to the converter box. Then pick your output connection. Either set the TV to channel 3 or 4 and connect the coax out from the converter to the TV or connect the composite video (AV) to one of the A/V inputs on the TV (change the TV source to the appropriate input). The source is changed with the remote (TV/Video button).
If you have other devices like a VCR in the connection sequence, you could connect the converter box to the VCR (and record on channel 3 or 4) and then connect the VCR to the TV as above. You will be limited to recording and watching the same program unless you get another converter box or tuner.
Programming the remote will depend on the box. For other set top boxes, the connections will be very similar.
I hope this helps.
Will not turn on no
If your television is not blinking light or giving any signal that it is plugged to a power supply, it simply means the television is not not receiving any power from the power source.
The problem is that the power panel of the television is bad and need to be replaced, Have a repairman replace the power panel and the television will be in good condition once again.
You can also replace it the DIY way, which simply is that you will have to unplug the television, then you unscrew it open, trace the power cord into the television and it will lead you straight to the power panel, then remove it from its compartment and assess it, if it has a bad capacitor then replace it by melting it off with a soldering iron and fixing in a new one and soldering it on it.
If it looks burnt, then you need to replace it with a new one.
Take care
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
