20 Most Recent Sony KV-28FX60 28" TV Questions & Answers
Tv keeps turning off
You replaced what bulb?
4/18/2014 5:07:51 AM • Sony KV-28FX60... • Answered on Apr 18, 2014
My 51 inch big screen toshiba powers off on its own
There should be some shored components at it circuit board. Check and replace it. If you wish to get more details, check this site.
3/24/2013 5:50:03 PM • Sony KV-28FX60... • Answered on Mar 24, 2013
How to change the bulb on a 2006 sony lcd projection tv
Send your email address to me by Fixya comment, and get back a copy of it customer manual by return mail. It have all details. Or visit the site named 'Electro-help'. Check this link and select the site named above. Check it after 30 minutes from now.
8/1/2012 2:18:02 PM • Sony KV-28FX60... • Answered on Aug 01, 2012
What is the code to enter into factory menu for sony triniton kv28fx60u
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web.Procedure to enter into service menu options to Sony Trinitron sets have been described in detail at the site. Pull up older posts. You will get what you want from there.
5/15/2012 1:44:04 PM • Sony KV-28FX60... • Answered on May 15, 2012
Need to tune a trinitron
there is only autotune button on the panel which means it programmes all findable channels in serial order. sorry to say there is no other way without remote commander.
9/11/2011 1:43:47 PM • Sony KV-28FX60... • Answered on Sep 11, 2011
2answers
5 BLINKS
My first guess is IC 702 in the crt drive circuit. You could open the back and unplug the "C" board from the back of the crt and then power it on. If the set comes up and you have good audio that will isolate the problem.
If IC 702 is the problem you'll have a couple of other things to check, R533 .47ohm 1/4 watt fusible resistor and C541 22uf 100v both on the "A" board because they tend to stress when IC 702 begins to leak. Replacing IC 702 and not the resistor and cap could cause 702 to fail again.
If IC 702 is not the problem then it could be the flyback.
Hope this helps!
Bill
8/26/2011 2:10:49 PM • Sony KV-28FX60... • Answered on Aug 26, 2011
My sony KV 28-F tv has an overall red Hue which
That is either a failing tube or a problem with the colour balance circuitry. Judging by its age, likely to be tube tracking.
1/30/2011 11:37:23 AM • Sony KV-28FX60... • Answered on Jan 30, 2011
Sony 60in Grand wega keeps
The dish network tech isn't the cause of the problem, it just a coincidence.
You TV is having a power problem and this could either be from your TV's line transformer or the TV power board.
To access the line transformer of the TV, open the TV, at the back of the TV tube, you will see a rubber pipe passing from the tube to the TV board, that's the line transformer.
In the case of power board, The power supply board might be defective that's why the TV power on and off, a capacitor, diode, etc on the power board may have been faulty. Until these bad components are replaced, the TV might keep behaving this way.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
Good luck.
9/18/2010 2:18:50 PM • Sony KV-28FX60... • Answered on Sep 18, 2010
7answers
SONY TV KEEPS TURNING ITSELF OFF!!
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
8/25/2010 5:45:30 PM • Sony KV-28FX60... • Answered on Aug 25, 2010
I have SONY Model #
Does picture disappear once in a day or happens many times while watching tv?
Let me know to diagnose problem.
Thanks.
7/6/2010 6:18:57 PM • Sony KV-28FX60... • Answered on Jul 06, 2010
Why does my Sony 57
Sounds like a heat problem. Check to make sure that if it has a internal fan that it is working, and clean any dust build up, most projection tv's have fans, usually the number of flashes indicate a code that repeats.
3/16/2010 2:18:10 AM • Sony KV-28FX60... • Answered on Mar 16, 2010
Wii tune in on sony kv 28 fx
sir u can connect both as front n back,connect only on av input n select the av button in your remote once u press u can view the first input then as followa second
12/26/2008 10:42:06 AM • Sony KV-28FX60... • Answered on Dec 26, 2008
TV Turns self off- 4 blinks on standby light
Yes, the blinks are error codes. I would not bother trying to figure out what they mean, I can tell you right now. Expensive repair. Average repair costs are 1/4 to 1/2 of the TV's current worth. Most likely a bad transistor. The average expected life span of a TV set is 3-5 years. After that, stuff starts wearing out fast. Time to move on.
11/14/2008 7:43:51 PM • Sony KV-28FX60... • Answered on Nov 14, 2008
Sony Kv 2780R trinitron 26" tv
Hi Mike,
my suggestion for you is to use a rubber inner tube, cut in half.
also the use of glue i would,nt recommend, but something more flexible such as silicone sealent.
mike @ compurepair.
5/22/2008 7:49:43 AM • Sony KV-28FX60... • Answered on May 22, 2008
I need the code from my Sony RM Y180 television remote to operate my Sony CD/DVD PLAYER DVP-NS57P please?
Question edited for clarity. This is unlikely to work, although I do see the remote has a VCR/DVD Source button. https://www.amazon.ca/Players-Kv-20Fv300-Kv-27Fa310-Kv-32Fs320-Kv-29Fs120/dp/B0874DLQMP And Sony says it is not programable DVP-NS57P The model is not programmable. https://www.sony.com/electronics/support/remote-control-programming/models/dvp-ns57p https://www.google.com/search?q=sony+dvd+remote+codes You can buy a Copycat remote for the DVD Player if yours is lost. https://www.google.com/search?q=DVP-NS57P+replacement+remote ..
4/22/2024 8:10:05 PM • Sony Televison &... • Answered 2 days ago
My sony tv bravia model klv 32v400A has no picture but the mauns light turns from red to green using the remote. What is the problem please?
This TV is 10 years old and probably requires a service that replaces the backlight invertor or just a power supply issue. Check to see if the light blinks. (That is the fault code and then google the result for more information).
4/21/2024 7:49:57 AM • Sony Televison &... • Answered on Apr 21, 2024
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony KV-28FX60 28" TV Logo
23 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony tv keeps turning itself off
  • Televison & Video
