20 Most Recent
Sony FD Trinitron WEGA KV-27FV300 27" TV Questions & Answers
Sony 32" trinitron perfect picture, but no sound
Check its speaker first. It sounds that the speaker is out. If it is found OK, check for any loose solder terminals at the audio output section circuit, of damaged component/s there.
9/16/2012 12:41:44 PM •
Sony FD...
Answered
on Sep 16, 2012
No picture (all snow).
Try hooking a DVD etc to one of the rear inputs to see if it works that way--if so you may have a bad tuner in the set but there are ways around that.
4/2/2012 10:30:57 PM •
Sony FD...
Answered
on Apr 02, 2012
It will not go on
try unplugging the power cord for 10-20 seconds then plug it back in. This is a when all else fails try. If it doesn't work it sounds like the T.V is going out. Check your T.V's handbook it might tell what the issue is.
6/26/2010 2:27:05 AM •
Sony FD...
Answered
on Jun 26, 2010
KV27FV300 PIP
I think that is dried solder try to re solder the video chroma ic or change the capacitor 250v/10uf near the FBT (flyback)section
7/30/2008 4:14:04 PM •
Sony FD...
Answered
on Jul 30, 2008
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
