20 Most Recent
Sony KV-XJ29M50 29" TV Questions & Answers
Horizandal transistor short
Check the deflection yoke for winding short. Check all the solder terminals around the capacitors of the horizontal output transistor for any loose soldering terminals. re-solder all the suspected ones, by applying a little more solder to each terminal. Check the LOT too. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy.
The wall plug does not fit in the wall socket, it has weird prongs
If the power plug prongs are not the same as what you normally have, (assuming the prongs were not messed up, i.e. they are from a foreign country) you can get and use an adapter ... that fits the "weird prongs" on one side and has the "normal" prongs on the other side ... to plug into the outlet.
Sony KV- XJ29M50 led flashing 2 time
- Two
blinks - B+ over current protection (OCP), unit goes to the standby mode
then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
Visit the site named 'Electro-help' for more
details. Click this link. View it in
'Flip card' option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. There
are more than 900 posts to different brand TVs now.
CAN WE CONNECT EXTERNAL SPEAKERS TO SONY KV-XJ29M50 TV
Check whether there is an audio out RCA type sockets at the rear side of the TVm marked as Audio Out. If so, you can connect these sockets to any exterenal audio amplifier, by connecting Av cable in between devices, and can listen audio from external speakers. Picture of AV cable is shown. Keep free its yellow pins. Use red and white.
