20 Most Recent Sony FD Trinitron KD-36XS955 36" TV Questions & Answers
Could be an open internal fuse or power supply failure
Sony FD... | Answered on Nov 04, 2018
get the sky box repaired
Sony FD... | Answered on Apr 19, 2017
Count how many times the standby light blinks at one time. These blinking are fault indication. You can get an idea about the faulty circuit part inside, from these number of blinks. After make it sure, if you wish to get more details about Blinking Codes to Sony TV sets, check this link.
Sony FD... | Answered on Feb 17, 2013
Check its picture settings. Refer to its user manual for details. Click here to download the user manual, if you do not have it with you now.
Sony FD... | Answered on Sep 17, 2012
Please replace 2 ICs on DZ board of tv to solve the issue as discussed in chat session.
Thanks.
Sony FD... | Answered on Jul 11, 2011
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Sony FD... | Answered on Jun 08, 2011
CAN I USE HEAD PHONE IN MI TV
Sony FD... | Answered on Mar 03, 2011
A protection circuit has cut in - possibly due to a fault in the line output stage (flyback transformer could be short-circuit and horizontal output transistor could also be shorted).
Assuming the power supply/HT rail is all OK, replace the above parts, touch up any suspect solder joints, check and replace any capacitors (electrolytic and the tuning caps in the collector of the horizontal transistor - always replace these caps (rated at around 2kV - 6kV) whenever you replace the flyback)
Sony FD... | Answered on Feb 18, 2011
It is one of two issues, the blue video driver is defective, or the blue gun in the picture tube is open. This will need a tv tech to varify the problem and suggest a course of action.
Sounds like the power supply.
Sony FD... | Answered on Oct 31, 2010
Please explain what it is that you are trying to program.
Is it the remote you are trying to program? Or the set itself? I can help if you give me more details.
Sony FD... | Answered on Apr 17, 2010
On your component cable (GREEN/BLUE/RED) check the connector for the RED on on both the TV and the device it is connected to. Also check the the RED for the VIDEO and the RED for the AUDIO are not switched on both the TV and the device as well.
Good Luck...
Sony FD... | Answered on Feb 24, 2010
You need a new Lamp
Sony FD... | Answered on Sep 20, 2009
well intermittinly shutting down only thing i can say is go thru that board may be getting good reading on transistor pull them out recheck
sounds like a bad cap make sure nothing is soldered together start from the beginning good luck shad tv man
Sony FD... | Answered on May 03, 2009
Sony FD Trinitron KD-36XS955 36" TV Logo
40 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
standby light wega blinks 6 times goes
  • Televison & Video
