20 Most Recent
Toshiba WRC 1000 Wireless Cable/DSL/Ethernet Router Questions & Answers
Itouch can't see my network
Not that I am aware of , but you signal strength will degrade if all the devices are on and using at once. Also your ISP MAY "throttle" your service/signal with high data usage. That said, Your iTouch and xBox, in the setting , wireless, the iTouch should see the signal, Is the wireless turned on? It's discoverable? If your wirell has a Password, has a setup box on the iTouch asked for the password? Use the Manuals for the devices to troubleshoot connections.
Unable to connect internet
hi,
theres a possiblity that the modem is set to bridge mode,in that way,you will not be able to connect to the internet direclty to the modem,192.168.1.1 is usually the deault gatewayy address for almost all verizon modem and username is admin and password is admin as well,if admin didnt take for the password,try using password as the password
thanks and God Bless
Toshiba WRC 1000 as a Wireless bridge
lets get the picture right. laptop connects to a wireless router. then u want to plug into laptop ethernet wan port of linksys ? you have to set router manual settings to gateway which is ip of toshiba... this is a fun topic. ive connected xbox360 to laptop this way.. never tried router. "fun times ahead!"
Password troubles.
remove power from the router and then using a paperclip reset the router holding the paperclip in for about 10 seconds....reattach 1 cable going from your computer to the router and log into the router, open your browser, type in the access address, enter the default factory user name and password,,, then setup your router accordingly,,,,follow the setup procedures from the manufacturer
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
