20 Most Recent Sony SLV-N750 VHS/S-VHS playback VCR Questions & Answers
Intermittent loss of video (mimicking dirty heads symptoms)
As JSE suggested. Also dump any very old tapes. As you say some play perfectly, I suspect, from personal experience, that faulty ones are either very old, or if recorded on another machine, may be mismatched with your current player.
1/18/2018 11:11:28 AM • Sony SLV-N750... • Answered on Jan 18, 2018
HOW DO I RECORD WITH A SONY SLV-N77 MANUAL DOES NOT HAVE ANY DIRECTIONS
Looks like a great brand with good features for the price.
  1. Connect Video & Audio Cables to a video signal source
  2. Connect Power Cable
  3. Turn on VCR.
  4. Insert a blank tape in the VCR.
  5. Note - A Broken Tab on the back of tape will prevent recording. This is called Write Protection.
  6. Cover the tab hole if you want to record over old video.
  7. Press RECORD on the VCR remote control.
  8. After a minute, press Stop, then PLAY to see recording.
  9. Cheers
8/19/2014 9:45:28 AM • Sony SLV-N750... • Answered on Aug 19, 2014
2answers
I have a Sony SLV-EZ717
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
11/26/2013 1:36:54 AM • Sony SLV-N750... • Answered on Nov 26, 2013
Need new sony vcr remote
Try searching Curry's Partmaster website, if you are in the UK.
4/2/2013 3:10:54 PM • Sony SLV-N750... • Answered on Apr 02, 2013
Player wont turn off?
The most likely problem is that the mechanism is not reaching a stop position in order for the deck to be able to be turned off. This cane be due to loose belts or a harden grease in a cam operated mechanism.In any case it needs service- I used to work on VCR's all the time .
2/24/2013 10:22:28 PM • Sony SLV-N750... • Answered on Feb 24, 2013
2answers
Sony SLV-N750
Check "SAMS" repair manuals.
8/28/2012 12:12:24 AM • Sony SLV-N750... • Answered on Aug 28, 2012
VHS tape is stuck in
This is often a frustrating problem but if you feel you can handle it go ahead with the following, otherwise get professional electronics help. If you have tried to eject the tape and tried other obvious ways to extract the tape and nothing has worked then you can remove the top cover and manually remove the tape. It is not that hard to do most of the time. First unplug the power cord from the wall outlet. You do not want to get a short or get shocked or zapped. Just unscrew the screws holding the cover in place and set the cover aside. Look at the tape to see where it is hung up. If you need to push the tape around so you get it off the posts or otherwise free up the tape, then gently do so until you free the tape from the tape transport. Sometimes this is all you need to do to extract the tape. You may be able to push out the tape from the VCR at this point. If you can get all the magnetic video tape back into the cassette but the tape simply will not come out then place the cover back onto the VCR, plug the VCR into the wall outlet, power on and try to eject the tape now. Sometimes this works. If all else fails, take the VCR into a electronics repair shop and have them remove the tape for you. They may tell you the VCR needs repairs also so this does not happen again.
3/31/2011 12:43:44 AM • Sony SLV-N750... • Answered on Mar 31, 2011
My Sony SLV-N750 Video Recorder does not record
Check the audio/control head for damage and any conections to it. The audio head could also have failed.
2/15/2011 11:07:22 PM • Sony SLV-N750... • Answered on Feb 15, 2011
I would like to know how to conect a Sony VHS to a
hi,
you can connect the audio video out of your VHS to the audio video input of your tv. for that you need an audio video cable (have three RCA pin at the both side, one for video(yellow) and the other two (red and white) for audio.
connect the one end of the three rca cable to the VHS's audio video out according to the color code. and the other end to the tv's audio video input.
Then select the corresponding AV input in your tv using the remote.
ok
1/25/2011 12:36:25 PM • Sony SLV-N750... • Answered on Jan 25, 2011
WILL NOT TRACK. +/- BUTTONS ON FROM OF VCR ARE
I will assume you have tried to clean the video head, if you have not use a wet or dry cleaning tape "dry better choice" and see if that will work, the other option is use a brand new store bought blank tape T120 and set the vcr speed at sp and let it run all the way through. If all this fails it means either the video head is bad or you need alignment done inside the vcr.
1/10/2011 6:09:55 PM • Sony SLV-N750... • Answered on Jan 10, 2011
Our Sony Video cassette recorder model SLV_N750
The problem is the idler assembly or the black square belt that drives it, this will cause the vcr to shutdown preventing tape transport. The vcr will need to be dismantled for repair, I recommend a tv technician to check your machine with an estimate.
1/8/2011 3:28:41 AM • Sony SLV-N750... • Answered on Jan 08, 2011
Sony SLV-N750 VHS/S-VHS playback VCR Logo
Popular Tags
72 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony slv n750 tape doesnt reel back
  • Televison & Video
