20 Most Recent Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Questions & Answers
2answers
Green Cloud show close to mid lower left center on most black screen
you will need the optical unit cleaned, if that does not resolve then the optic unit needs replacing
11/18/2020 12:08:08 PM • Sony Grand WEGA... • Answered on Nov 18, 2020
Problem with Sony Grand Wega KF-60XBR800 60 in. Rear Projection HDTV
Power supply board issues
2/7/2018 3:51:35 PM • Sony Grand WEGA... • Answered on Feb 07, 2018
I have a red ghosting problem on my TV.
set should have magic focus. use it or adjust convergence manually.
12/10/2014 7:05:03 AM • Sony Grand WEGA... • Answered on Dec 10, 2014
3answers
Ghost images
Sounds like a light engine issue to me. Is there anyway you can post a picture of the issue itself?
12/9/2014 8:17:23 PM • Sony Grand WEGA... • Answered on Dec 09, 2014
Sony KF50XBR800 Turn off and on issue
You will need to replace your bulb.
It costs around $ 300.00 for a new bulb.
After you have installed it, your TV will look new once again.
12/15/2013 10:18:11 PM • Sony Grand WEGA... • Answered on Dec 15, 2013
2answers
Sony grand wega started turning on and off continuously
codes consist of N blinks, a pause and N blinks again,valid error codes are 3, 4, 5, 6 & 9 blinks.
6/16/2013 2:16:14 AM • Sony Grand WEGA... • Answered on Jun 16, 2013
Ghost image - told by tech that optical unit needs to be replaced
Your set is a dlp..dlp require no convergence. there may be some small adjustment in a custmer menu... but not enough to make a difference. Sorry yes light engines are expensive. thats most of the sets inside
6/16/2013 2:15:33 AM • Sony Grand WEGA... • Answered on Jun 16, 2013
TV turns on and off by itself
replace bulging electrolytic capacitors in the power supply will solved the problem.
9/17/2012 2:35:05 AM • Sony Grand WEGA... • Answered on Sep 17, 2012
Sony wega wont turn on
see previous answer give for same question posted just a little different.
3/19/2012 6:24:48 PM • Sony Grand WEGA... • Answered on Mar 19, 2012
Red indiacator light flashing three times
You can look in the owners manual which will list the error codes and define each (if you do not have it GOOGLE the full model number with "manual" and locate it.On some of these (not sure if your model) 3 blinks is lamp door not closed---on those it does not mean that but means the door has been warped and a peg on the back is not engaging the safety switch which prevents set from coming on if door was removed.The door can be examined by removing outer plate where lamp is inserted and looking at it edgewise to see if warped.I can tell you to test this: Remove lamp door--inspect it--where plastic peg on back of it is behind you will see a tiny lever--with something not metal engage the lever forward and hold it.If set comes on this way door is the problem and easy to replace (lots of places if you GOOGLE the MODEL number and door you will find the part.If set works this way: DO NOT OPERATE SET FOR PROLONGED PERIOD OF TIME AND DO NOT LOOK AT LIGHT AS IT CAN HARM YOUR EYES---DO NOT OPERATE SET IN THIS CONDITION OR REPLACE OUTER PLATE BACK WITH DOOR REMOVED- it can melt the outer plate or damage it.
3/19/2012 6:24:03 PM • Sony Grand WEGA... • Answered on Mar 19, 2012
Changed out rear bulb and
Make sure the lamp door is closed correctly with security strap tightened. If the door is not just right, it will give you the same result as a bad bulb.
12/10/2011 3:34:07 AM • Sony Grand WEGA... • Answered on Dec 10, 2011
My Sony KF50XBR800 2002 model
Replacement lamps do not last long. Unless it is the Sony MFG lamp, they only last about a year or so with normal use. Otherwise, the only other suggestion I could give you would be to replace the ballast. Not to expensive either, 40-50. hope this helps as well
12/10/2011 3:32:26 AM • Sony Grand WEGA... • Answered on Dec 10, 2011
My TV shuts off automatically
First, Clean the fan on the rear of the TV with Dust off and re test, if the problem persists, replace the lamp. It's either overheating and protecting itself or the lamp is bad. Lamp should run you from 60-70 online. Hope this helps
12/10/2011 3:29:17 AM • Sony Grand WEGA... • Answered on Dec 10, 2011
Kf-50xbr800 turns off for about
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
8/22/2011 1:50:52 AM • Sony Grand WEGA... • Answered on Aug 22, 2011
Tv cycles off and on every 30 seconds
Replace the lamp. Very easy to do and lamps can be found on EBAY for 120-140.
Hope this helps
7/11/2011 1:20:32 AM • Sony Grand WEGA... • Answered on Jul 11, 2011
Is my some grand wega kf-50xbr800 able to get
I do not believe so.....
6/10/2011 10:54:05 PM • Sony Grand WEGA... • Answered on Jun 10, 2011
I replaced the lamp on
Are you sure that lamp is Sony original?
Aftermarket/ low price lamp wont work as compare Sony original lamp.
Thanks.
6/3/2011 6:39:25 PM • Sony Grand WEGA... • Answered on Jun 03, 2011
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
Popular Tags
108 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony model
  • Televison & Video
