20 Most Recent Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Questions & Answers
Replaced lamp 5 mnths ago now grn lht flashes then red lght fashes
May have lost lamp again. Vacuum (do NOT blow) out the area around the lamp housing and the fan above it, before replacing it
5/8/2014 2:46:47 AM • Sony Grand WEGA... • Answered on May 08, 2014
Blinks green, the red three times and pause then red threetime
Lamp door not closed is what it means but it is usually a issue:Set has where the door is at a tiny lever (remove door to lamp) that is engaged by a plastic peg on the back of the lamp door--the lever is a safety switch to prevent set from being used with the door removed.What happens in these sets is heat from the lamp can warp the door just enough so the peg no longer engages the lever.Side note: some of these is got so bad it damages the housing where the lamp goes into the set--I have myself had to cut two doors to get them out-rare but can happen.A simple way to prove or disprove this is take something not metal (I use a Q tip) and engage the lever forward---Turn set on and if it comes on the door is your problem.DO NOT OPERATE SET FOR A PROLONGED PERIOD OF TIME AND DO NOT LOOK DIRECTLY AT LIGHT FROM THE LAMP AS IT CAN DAMAGE YOUR VISION.WITH DOOR REMOVED DO NOT PUT OUTER PIECE BACK ON AS HEAT CAN MELT OR WARP IT ALSO.IF SET COMES ON AND WORKS REPLACE THE DOOR.
6/16/2012 6:35:20 PM • Sony Grand WEGA... • Answered on Jun 16, 2012
2answers
How to reset lamp timer on a sony tv KF-42WE610?
It should be in the general settings menu under lamp replacement. It will ask you if you've replaced it already. Hit yes.
5/25/2012 10:56:16 PM • Sony Grand WEGA... • Answered on May 25, 2012
I have small blue dots and a yellow shadow in the middle of my screen
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.Let me know if you have questions.
12/3/2011 2:31:12 AM • Sony Grand WEGA... • Answered on Dec 03, 2011
I have a Sony KF42WE610 when I hit the power
The 17Volt supply is missing. The G1 board will need to be replaced sony part A1302272A you should be able to get a G1 board from www.tvcircuitboards.com
10/14/2011 1:11:57 PM • Sony Grand WEGA... • Answered on Oct 14, 2011
I have a kf42we610 how
if you look close at the screws and recessed screws, They generally put an arrow pointing at each screw that is necessary to be removed.
Good Luck!
8/31/2011 1:25:34 AM • Sony Grand WEGA... • Answered on Aug 31, 2011
Sony KF-42WE610 Once we
Thats an issue with the G1 circuit board. You can get the G1 board A-1302-272-A from www.tvcircuitboards.com under the Sony DLP and rear projection circuit boards.
8/21/2011 12:38:10 PM • Sony Grand WEGA... • Answered on Aug 21, 2011
The green light on my
Replace your lamp.
7/20/2011 5:44:58 PM • Sony Grand WEGA... • Answered on Jul 20, 2011
I can see old twisted cobwebs, now tangled,
xxlracer,
See my tip at http://www.fixya.com/support/r4690955-clean_lense_screen_in_projection_tv for help.
Thanks for using FixYa and for the great rating.
hardrocko
6/14/2011 1:40:17 PM • Sony Grand WEGA... • Answered on Jun 14, 2011
2answers
My sony won't turn on.
six times means the thermal fuse on top of the lamp tripped. Replace it and give it a good cleaning and it should work.
4/23/2011 11:03:57 PM • Sony Grand WEGA... • Answered on Apr 23, 2011
I dont know how to
if you have a cable box you have to turn on the cc within the box menu.
3/22/2011 6:05:31 PM • Sony Grand WEGA... • Answered on Mar 22, 2011
BLUE FINGER LIKE STREAK ON TOP RIGHT HAND CORNER
Sony A10/A20 TV Class Action ' Home Follow this link to the world of Sony optical block headaches. There have been three class actions so far, and a few more in the wings. Contact Sony customer support and climb the ladder if necessary. Hope this helps
1/16/2011 2:51:42 AM • Sony Grand WEGA... • Answered on Jan 16, 2011
2answers
The red standby/power light blinks and the tv
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
1/11/2011 2:19:37 AM • Sony Grand WEGA... • Answered on Jan 11, 2011
There are thousands of small
both problems would most likely be fixed with and optical engine replacement. due to cost it may not be economical to repair new purchase may be smarter. part number---A-1606-006-A $668.51plus tax and labor.
12/23/2010 4:23:25 AM • Sony Grand WEGA... • Answered on Dec 23, 2010
I have a SONY KF-42WE610. When I turn it on a red
according to service manual 3m blinks indicate the lamp door cover is loose or open
12/13/2010 1:13:11 PM • Sony Grand WEGA... • Answered on Dec 13, 2010
TV WONT START UP - RED LIGHT COMES ON AND THERE IS
if the lamp has gone the bottom light will flash if the top flashes there a problem with the tv there is reset you can do
  • Point the Sony remote control at the TV and press and hold the "Up" arrow button.
  • 3
    Push the "Power" button on the TV while holding down onto the "Up" button. Release the "Up" button when the TV turns off, then turns back on.
  • 4
    Select "OK" when shown the factor settings and the television has completed its TV reset
  • Read more: How to Completely Reset a Sony TV with a Blinking LED ' eHow.co.uk http://www.ehow.co.uk/how_6011902_completely-sony-tv-blinking-led.html#ixzz17Eijjdrn good luck regards shaun
    12/5/2010 11:39:08 AM • Sony Grand WEGA... • Answered on Dec 05, 2010
    Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
    98 questions posted
    Top Sony Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ZJ Limited
    ZJ Limited
    matt martin
    matt martin
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
    View Most Popular
    • Sony Televison & Video
    Most Popular Question
    small blue dots yellow shadow in middle
    • Televison & Video
