20 Most Recent
Samsung Acclaim SCH-R880 Questions & Answers
Reset schr 880 cell phone
Here is how to perform Samsung SCH-R880 hard reset:
1. Turn off the phone
2. Press and hold the volume down key, the power key and the navigation key at the same time until you see a black screen with blue writing
3. Use the volume keys to select the factory reset.
Reset unlock pattern
What kind of phone is it? Most Android devices have a "recovery" mode you can get into. Whatever kind of phone you have, google "your-phone-here recovery mode" and see how to get into recovery - which will likely be done with some sort of button combination from the powered-off state. Once you're in recovery mode, choose wipe data / factory reset, then reboot, and you'll have a clean, "like new" phone, and the pin will be gone. It'll reset your phone to start from scratch, but then you'll also be getting rid of that pin.
How do i reset my phone if i forgot my password?
You can reset your Samsung Acclaim SCH R880 by performing below instructions:
Press and hold the Volume key down + Optic pad/OK key + Power/Lock key
Hope This helped. REMEMBER ALL DATA WILL BE LOST Including contacts,pictures,music etc
The last few weeks my
JUST TYPE THIS CODE TO RESET EVERY THING ON UR PHONE AND IT WILL RESET TO FACTORY SETTINGS *2767*3855#
How to hard reset Samsung st1000 camera
To hard reset your Samsung ST1000 camera, follow these steps:
Reset Settings via Camera Menu:
Open the camera app.
Tap on the Settings icon (usually represented by a gear).
Scroll down and select Reset settings.
Confirm the reset by choosing Yes when prompted.
Physical Reset (if needed):
Locate the reset button on your camera (refer to the camera's manual for its exact location).
Press and hold the button for at least 10 seconds until the camera restarts
Samsung S9 turning Samsung Music app on by itself
This seems to be a known issue where the Samsung Music app starts randomly1. Here are a few steps you can try to resolve this issue:
Check if an app you downloaded is causing the problem: Start the phone in Safe Mode. If the problem does not occur in this mode, then you need to find out what app this is and uninstall it.
Wipe the cache partition of the phone from the recovery mode: This can often resolve issues with apps misbehaving.
Perform a factory reset: Please remember to backup your phone data before doing this. Once the reset is complete, do not install any apps in your phone yet. Try to check first if the issue still occurs.
Check Power Saving Mode: The power saving mode could interfere and block your music-streaming app if turned on.
If none of these steps work, it might be a good idea to contact Samsung's customer service for further assistance.
