20 Most Recent
Sony SA-VA1 Rear Speaker Questions & Answers
How do i hook up the wires from and to a sa wms
what r you hooking it to is #1 rca wires r the way to go when hooking up a subwoofer up .some subwoofers have 2 rcas on them one input and one output the in put is mono if what your going to hook it to has rcas on it then the left one is a mono output but if its an audio system then it mit have a subwoofer output on it
THE SEARCH FOR SONY SA-VA1 SPEAKER WIRES
HEY COWBOY, I ALSO JUST PURCHASED A SET OF THESE TODAY FROM A D.I. STORE IN SALT LAKE (JUST LIKE GOODWILL BUT MANY TIMES BETTER) I TOO NEEDED THE CABLES AND FOUND THEM ON EBAY. HERE IS THE ITEM DESCRIPTION MAKE SURE TO ENTER IT INTO THE SEARCH BOX EXACTLY LIKE I AM GIVING IT AND IT WILL TAKE YOU DIRECTLY TOO THE ITEM.HERE IT IS....Sony #177553111 SAVA SA-VA 1 27 29 55 57 59 SPKR CABLE IF YOU HAVE ANY PROBLEM PLEASE EMAIL ME. i also bought the cable it was i believe 24.95 and 7.95 shipping i think. i used to own this set and they are a very nice tower speaker and sound very good i was fortunate to get mine today for 15.00 minus the center and rears. later jim
I have a soney flat
What is the model of the flat screen TV and theater system? Check the back panel for model numbers.
Reply back and I'll direct you to a PDF manual for those devices.
The system worked fine but has an intermittent
They are prone to bad solder connections on the power regulators and output ics. should only be a labor charge. est $60 -100
Not very easy to take apart, need to remove several screws on rear of unit, remove front grill remove some screws on front. disconect connectors remove amp and power supply board, resolder bad connections and re-assemble. I've done several would take me 30-45 min.
