20 Most Recent Sony SA-WX700 Subwoofer Questions & Answers
0answers
0answers
I have a Sony SA-WX700 Subwoofer and it powers up
Replace amplifier output big IC that seems defective and not giving sound to speaker.
Thanks.
10/3/2012 2:47:18 AM • Sony SA-WX700... • Answered on Oct 03, 2012
My sony SA-wx700 sub woofer does not have a sound
Check out this link to a thread. I bought a Sony SAWX-700. The light came on when plugged in. The guy said he didn't have a way to test it, but assured be the light was on and that it worked. I got home and it didn't. Did a search and found these posts. I followed them, ordred the parts and fixed it for like $10.00.Hope this helps! I also did a Youtube search on how to solder and desolder and wasn't that hard. http://www.avsforum.com/avs-vb/showthread.php?t=944798
11/20/2011 9:28:28 PM • Sony SA-WX700... • Answered on Nov 20, 2011
2answers
Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
8/25/2010 8:31:16 PM • Sony SA-WX700... • Answered on Aug 25, 2010
0answers
2answers
Have a sony sa-wx700 home
THI NOISE IS CAUSED BY A FAILING TRANSISTOR IN THE AMPLIFIER, AS THE TRANSISTOR FUNCTION COMES AND GOES IT MAKES A STATIC POP, U WILL NEED TO HAVE IT REPAIRED OR DEPENDING ON THE REPAIR COST REPLACED.
6/15/2010 9:39:20 PM • Sony SA-WX700... • Answered on Jun 15, 2010
Power turns(light) but no sound. Fuses all good??
apparently there is are some components on the main board that need replacing:
This is usually what needs to be replaced on these subs.
Replace
R830
R831-4.7 ohm 5% 1/4w fusible
C860 - 082 mf 5% 50v
Direct from Sony:
hxxp://servicesales.sel.sony.com/ecom/accessories/web/index.jsp
c860 is Part # 113616400 $2.14
r830 is Part # 121284900 $2.14
4/8/2010 2:33:44 AM • Sony SA-WX700... • Answered on Apr 08, 2010
I have an SS-wmsp66 sony subwoofer that I want to
No way. It's glued and screwed from the inside.
3/29/2010 4:47:10 PM • Sony SA-WX700... • Answered on Mar 29, 2010
My sony sa-wx700 after being
A connection that goes bad when it warms up or the amp part of it is going bad....
3/12/2010 8:47:41 PM • Sony SA-WX700... • Answered on Mar 12, 2010
Sony SA WX 700 - Fuse (6.3 A 125V) keeps burning out
The switching power supply transistors have shorted out. Other parts may be gone also. A difficult fix. Too bad, it's a great sub.
3/12/2010 8:27:35 PM • Sony SA-WX700... • Answered on Mar 12, 2010
Sony SAWX700, powers on fine, subs are not blown but no sound
The problem may be with the preamp power supply section. Easy fix in most cases. This is a great sub, they don't build them this well anymore. From Sony, I was quoted around $200 plus the bad board in exchange. The part to fix it costs $1.00, labour an hour or less. Get it fixed. The other brands have gone cheap with components and build quality. Let me know if you want more info.
3/12/2010 8:23:45 PM • Sony SA-WX700... • Answered on Mar 12, 2010
Humm noise coming from 10" 100watt sub only plugged into wall...
If you're using it first time, check the sub cable u're using, low-quality rca cables can easily pretend to act as an antenna and pick up parasite and hum from electric lines or from other devices, also another factor is too-long cable. If u're using a cable longer than 5m, it should be really hi-quality and well screened. Or the hum is inevitable. I hope this helps.
1/3/2010 10:56:56 AM • Sony SA-WX700... • Answered on Jan 03, 2010
My sony sa-wx700 has blown the 6.3 amp fuse on the
i can't open yahoo mail in box
12/27/2009 9:26:50 PM • Sony SA-WX700... • Answered on Dec 27, 2009
Sony SA-WX700 Subwoofer Logo
34 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
power turns light but no sound fuses
  • Audio Players & Recorders
