20 Most Recent
Sony MDS-JB940 Mini Disc Player Questions & Answers
Do not ejecting
Take the lid off and give the disc a gentle push. Beware paper labels coming off.
I have a Sony MDS-JB
Pull off the top cover, then remove the inside cover of the loader mechanism and you can gentily remove it.Your loader meahanism is worn out, you need to get another similar unit perhaps on ebay to replace it.
Push protect problem/ sony MHC-VX33
push power protect is error signal shows problem in power amplifier board, mostly power amp out
IC STK402-100S found deceptive.
contact nearest Sony service center for proper repair.
The problem with my MDS-JB940 is when recording.
HELLO
Have you tried cleaning the lens? Even minidisc decks have to get the laser cleaned!
Power it off and take the lid off, then using isopropyl alcohol and a cotton bud clean the lens gently in a circular motion. Then try it again.
It may just work for you (:-)
I'm trying to record on
"The definiton in the manual suggests you are trying to record a digital bitstream that is either dead or incompatible with the recorder." That is completely wrong. DIN UNLOCK means what the first poster said - that you are trying to make a digital copy of a digital copy. You cannot (for legal reasons). Record via analog.ABSOLUTELY DO NOT TRY TO CLEAN YOUR LENS WITH ALCOHOL AND A Q-TIP. It has nothing whatsoever to do with your problem and you may well damage or destroy the lens or the transport.
Din unlock c-17 on sony mini disc
If “Din Unlock” flashes in the display
• The digital program source is not connected as you set
with INPUT
To continue, connect the program source properly.
• The program source is not on.
Turn on the program source.
