20 Most Recent
Giant Trance X4 Questions & Answers
How do i replace the
you need a crank puller to do that job. they dont cost much. once you take off cover off crank you screw crank puller in and use shifter or spanner to tighten bolt on crank puller and it will pull crank off easily, then undo main cover to access bearings. better to change both sides.
How do I raise the
Flipping it over might work, or get one with a higher rise, different reach. Get a bike shop to assist as there are 4 parameters to match up: steerer diameter, handlebar diameter, reach and rise.
I have a giant prime + e bike ,2014. How do I change from km to miles?
To change the unit of measurement on your Giant Prime+ e-bike computer from kilometers to miles, you can follow these steps:
- Turn on the computer by pressing the button on the underside of the unit.
- Press and hold the "Set" button until the screen changes.
- Press the "Set" button repeatedly until you see "UNIT" on the screen.
- Press the "Mode" button to select "UNIT."
- Press the "Set" button to confirm your selection.
- Use the "+" and "-" buttons to toggle between "KM" and "MILE."
Once you have completed these steps, your Giant Prime+ e-bike computer should display speed and distance in miles instead of kilometers.
