20 Most Recent
Sony CMT-NE5 CD Shelf System Questions & Answers
Loose? pad thingie (no disc)
HelloThe focussing secion coils inside the laser pickup unit is faulty. There is no repair to this fault, except replace the laser pickup unit with same type and number.
Cd player not working
HelloReplace the laser pickup unit along with its connection wire to main board. OK.
Device could not see CD
HelloLook whether the CD spins inside the set, after it has been loaded well. If not replace sled motor. Sled motor is one which do spins the disc inside. If disc spins inside, and the set do not read the disc, laser pickup unit is faulty, and should be replaced with same type and number. OK.
Micro hi fi component system sony cmt-ne5 / ne3 I
HelloCheck its sled motor. It is the motor that helps to spin the disc inside. If disc do not spin inside, check the voltage at the terminals of this motor. If it is alright, and comes near to 5VDC, the sled motor is damaged and have to be replaced. OK.
There is power going to the unit but I can't turn
HelloIts system control section does not get proper voltage to go on. Just check whether there is 5VDC comes to main system control section. If not, check the 5V regulator IC for damage or loose solder contact.
My CD disc skip will not release to allow CD to
HelloJust put a sens cleaning disc into the unit, and play it at least three times. If it does not help you, the laser pickup unit to your device should be replaced with same type and number. OK.
I have had the CMT-NE5
HelloReplace the flat strip wire that connects laser pickup unit to main board. If it does not help you, replace laser pickup unit with same typa and number. OK.
Hi fi says there is
Replace the flat strip connection wire that connect the laser pickup unit to main board first. If it does not helps you, replace the laser pickup unit with same type and number. OK.
'no disk' error message
HelloReplace the strip connection wire that connects the Laser Picku Unit to main board. If the fault prevails, the Laser Beam emission to your devices' Laser pickup unit is less, and must be replaced with same type and number. OK.
No disc error
HelloYou are not right. The fault is with its Laser pickup unit itself. Replace it with same type and number. OK.
When I insert a disc in my hi-fi it reads no disc
HelloThe problem may be due to its Laser Pickup Unit itsef. Just put any other good CD, which was played with this set earlier, and see whether it ireads the xisc and starts to play it. If not, put in a lens cleaning disc {which can be bought from most of the electronic spare part selleing shops at your town, and won't cost more}, play this disc at least three times, by ejecting it out from the set, and reinsert it in to it each time. This will clean the laser pickup unit's lens. If the fault is due to accumulation of dust or dirt, this will help you. If not, there is no other way than replacing the Laser Pickup Unit of the device, with same type and number. OK.
I've lost the remote for the CMT-NE5 and I do not know how can I activate the "MD" FUNCTION
You could try purchasing a 3 In 1 universal remote control unit.
These usually scan to find the matched frequency of your appliance, then you can turn on/off with the remote.
These are however limited, and you may not get all of the functions. As with the original remote as supplied.
Alternatively, contact your local supplier, they should be able to assist you further.
Mike @ Compurepair.
Connecting SONY TA-D505 amplifier LBT-D505
Hi David, do you want to connect the ST-D505 tuner to the TA-D505 amplifier?
You just have to connect an audio cable of two RCA (red and white) from the audio output L and R of the tuner ST-D505 to the input of Tuner in the amplifier TA-D505
Remember to connect the FM antennas and the AM Antenna Loop on the ST-D505 tuner
To listen to it, you have to select Tuner on the TA-D505 and enjoy the favorite radio stations
I hope you have my comments
Greetings Franco Dosil
Hola David, quieres conectar el sintonizador ST-D505 al amplificador TA-D505?
Simplemente tienes que conectar un cable de audio de dos RCA(rojo y blanco) desde la salida de audio L y R del sintonizador ST-D505 a la entrada de Tuner en el amplificador TA-D505
Recuerda conectar las antenas de FM y la Loop Antena de AM en el sintonizador ST-D505
Para poder escucharlo, tienes que seleccionar Tuner en el TA-D505 y disfrutaras de las estaciones de radio preferidas
Espero que te sirvan mis comentarios
Saludos Franco Dosil
https://elektrotanya.com/sony_lbt-d505_d505cd_d505cdm_d505m.pdf/download.html
