20 Most Recent Sony MHC-GX45 CD Shelf System Questions & Answers
0answers
0answers
When the radio turns on
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
9/15/2011 12:27:53 AM • Sony MHC-GX45 CD... • Answered on Sep 15, 2011
0answers
I dropped my phone battery
Try shaking the player upside down . You can also use a tweezer to pick this up. Or just open up carefully and take it out. Kindly rate my answer if you are satisfied or not. Thanks a lot . Good day to you . Deepak Richard
5/3/2011 4:47:45 PM • Sony MHC-GX45 CD... • Answered on May 03, 2011
I own a sony MHC-GX45. A while ago the left
Sorry, I have a similar problem and came here looking for a solution. I believe the problem is with the speaker or the speaker wire. When I move the "good" speaker to the other set of lugs, it continues to function OK. I wish I could get the speaker box open without major surgery, but, alas, they are not made for repair. Don't know if I will cut into the box. My temp solution is to turn the unit off/on. This gets both speakers working. Bit of a drag, but I am finding it real difficult to find a new system w a tape player.
4/21/2011 3:43:31 AM • Sony MHC-GX45 CD... • Answered on Apr 21, 2011
I had 2 watch type
These are foreign parts as nothing like them used in this hi-fi system.
9/8/2010 10:04:42 PM • Sony MHC-GX45 CD... • Answered on Sep 08, 2010
Power light only flashes
No that is the unit telling you I am shorted so I will not turn on as it could cause a fire. Most likely there is a short in the audio output amplifier. This unit will need to ba taken into a repair shop and diagnosed. Good Luck
3/19/2009 5:01:36 PM • Sony MHC-GX45 CD... • Answered on Mar 19, 2009
My right speaker is broken
http://esupport.sony.com/US/perl/contact-land.pl
You can also take it to a radio or electronic repair place and price a replacment speaker from them.
1/7/2009 8:27:57 PM • Sony MHC-GX45 CD... • Answered on Jan 07, 2009
How do I preset a second AM station on a Sony SRF-M97 Walkman
It looks like the manual knows, and you can have 5 AM station presets and 15 FM. https://www.google.com/search?q=preset+a+second+AM+station+on+a+Sony+SRF-M97+Walkman ..
4/18/2024 5:09:49 AM • Sony Audio... • Answered 11 hours ago
Sony PS-FL7 direct drive turntable. When start button is pressed it illuminates but turntable won't rotate. All other functions work as they should.
'Direct Drive' appears to mean something different to Sony unless the belt is for another function. https://lptunes.com/products/sony-ps-fl7-ii-ps-fl7-ii-psfl7-ii-turntable-tonearm-belt-replacement Service Manual
Sony PS-FL7 Stereo Turntable System Manual
Vinyl Engine https://www.vinylengine.com > library > sony > ps-fl7 Sony PS-FL7 owners manual, service manuals and schematics are for reference only and the Vinyl Engine bears no responsibility for errors or other inaccuracies. "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(56px);"> Rating: 8/10 · ‎ 4 reviews
SONY PS-FL7 service manuals download
NoDevice https://www.nodevice.com > ... > Vinyl Players > SONY SONY PS-FL7 service manual (Vinyl Players) in PDF format will help to repair SONY PS-FL7, find errors and restore the device's functionality. ..
4/6/2024 7:54:41 PM • Sony Audio... • Answered on Apr 06, 2024
My sony icf-cl75ip wont turn on and is making a clicking sound. How can I fix this?
There is not reason this would click and not turn on. If it just clicked, it would likely be caused by interference from another appliance, typically a fridge or freezer. The most likely reason is a relay in the internal power supply. It will need a Sony Service Centre. https://www.sony.com/electronics/support/res/manuals/4154/41545841M.pdf It isn't a recorded known issue. Sony are high quality equipment so it is worth getting it fixed. https://www.google.com/search?q=sony+icf-cl75ip+clicks+and+not+working ..
4/6/2024 2:59:06 AM • Sony Audio... • Answered on Apr 06, 2024
Hello Sir. My Sony Deck MHC RV-900D Stereo, it's front panel is not working. I changed the fuse, replaced it but after no response. Please Help me Sir, Thanks.
Open it up and look for bulging or split electrolytic capacitors, especially in the back to the display and the power supply. Or take to an electronics technician for diagnosis. https://www.google.com/search?q=Sony+deck+MHC+RV900D+not+working ..
4/3/2024 2:34:25 AM • Sony Audio... • Answered on Apr 03, 2024
Sony Music system error code display c81, what is minig
C81 error indicates an internal hardware fault.Check CD mechanism is not jammed.
3/3/2024 7:36:52 AM • Sony Audio... • Answered on Mar 03, 2024
Sony Audio Rack SU-S5520. Need a power cord for it please?
Question edited for clarity, turned around plus CAPS. It should be a standard figure 8 connector. https://www.google.com/search?q=sony+audio+rack+su-s5520+power+cord+replacement ..
3/1/2024 8:31:36 PM • Sony Audio... • Answered on Mar 01, 2024
Sony MHC-GX45 CD Shelf System Logo
Popular Tags
23 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
when radio turns
  • Audio Players & Recorders
