20 Most Recent
Sony CMT-HPX9 CD Shelf System Questions & Answers
THE VOLUME DIAL (LARGE ROUND
Some tuners denote volume as attenuation so zero means it is at full volume and -20 means it is 20 decibels or 20 percent etc below zero. Essentially, zero means it is not being held back while the higher the number, the higher amount of holding back.
I am not sure what you mean by the volume does not increase or decrease normally so you'll have to ask that one with more details and information to get something more on that issue.
Reading CD message
You can use a CD Cleaner as a first step, if it didn?t work the problem need an expert technician to clean the lens or replace it.
Good Luck
Toufic Malek
I have the Sony HCD
Hi windyridg312,
You must have a RCA plug to Baby plug cable for the connection. See below picture.
Hook up the the baby plug(black) to your ipod where your headset inserted.
Hook up the RCA plug (red and white) to the auxiliary input(back panel) of your Sony. Then select the Auxiliary input button to the front panel.
Play the ipod, the music(sound) will be heard now at the speaker of your Sony shelf system.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sony CMT-hpx7 - CD changer is stuck with 2 CDs
it a bit complicate to open
you can try but you need to remember what you open so you can put back in the same order
try this
first open the back cover you should be able the see the inside then you need to open the top cover now the changer can be open without power you need to locate the motor and turn the the belt or the wheel slowly and it wil take the disc out. """"""dont turb back""
you need to plug the power and let it go back alone after that disconnect the power and put back everything
its not so easy so before you do it make sure that you can open and put back
Hope it will help
I have a Sony CMT-HPX7 Stereo but i got a cd stuck
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealersip.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
For My Sony CMT-HPX9 [mp3]
Plug the cord into the headphones/mp3 port on the front and press function until the MD option pops up. It should work then.
CD problems
hi
you push the button and it dosent work?
maybe the button went bad
push harder
pull the button out ( if possible) and push with something small and hard
you hear anything after you push?
if soo then the drawer is stuck or the engine is about to die
(not enough power to open the drwer)
take a flat screwdriver and shove it (gently) between the carack of the drwer and try helping the drawer out
maybe a plastic wheel will brake from this soo be careful
in the end these system are ment to start dying after 5 years
soo if this is the case
sorry
wont do any good
have a good one
