20 Most Recent
Sony STR-DE345 Receiver Questions & Answers
Sony str-de345 this keeps on making a
the clicking is a power suplie overload some output amp is with problems and shutdown after overheat, when you tap is bad connection inside, normaly is related with sound off after 15min. needs to be checked by tech. to ensure perfect operation.
Reciever not working
Are all the speakers GOOD and all connected right?
If so then you have at least one blown output amplifier module.
Loud buzzing sound in the
The buzzing is caused by the power source of the receiver : the filtering capacitors from the power lines to the amplifier circuits have aged and have started to dry, lose their capacity so the current is no longer filtered correctly so the ripple from the AC mains is stronger and it's passed on to the amplifiers where it became audible.
Keeping the capacitors under constant tension will help them regenerate somewhat, but you will have in the end to replace them. A simple job, just be careful at the ratings of the capacitors when you get their replacements.
When i push a button
Hello, that happens when a reciever gets a few years old and only the remote control has been used.The switches are dusty i recommend pushing them in 50 times each ,i know it sounds silly but it will clean the contacts.
My STR-DE345 has no sound from the center channel,
The center channel on this model uses its own amplifier circuit that is independent from the others. It is usually a 5-9 pin IC attached to the heatsink. It is likely that this IC is defective and needs to be replaced. Unfortunately, I can not know this for sure without taking measurements inside the unit. There is no simple fix for this although this is an easy repair for a service shop. Please seek professional assistance to resolve this. Expect a parts cost in the $25 range.
Dan
My fuse keeps blowing, what
May be a number of things...the power supply may have a shorted component in it...or the audio output stage may be defective...if you can obtain a volt/ohm meter you can test the power supply diodes and the regulator/audio output transistors...you will need to use the diode check function or the ohm scale to check these semiconductors...they should read infinity in one direction and , on diode test, anywhere from 500-700 for silicon(which is what is used today)..on the ohms scale you should read 500-2000 ohms in one direction and infinity in the other...if you get a 0 reading on any of the semiconductors..then it is shorted and will need to be replaced
