STR-DE525 Blown fuse
Not very likely that you can fix it yourself with little electronic skills. You fried the channel you had it connected to. It will require the replacement of a lot of parts in the amplifer circuit. When a channel blows it has several transistors, several resistors, sometimes a couple of diodes and capacitors, and sometimes with the sony amplifers a pre-amp driver IC that will need to be replaced. You will require a multi-meter to determain which parts must be replaced, a soldering iron, some solder, and some solder wick to remove the solder from any bad components that must be replaced.
Any time you connect more than 1 speaker to a channel you risk over-heating that channel and shorting out some components. There are no amplifiers that are designed for more than 1 speaker per channel. I have repaired many sony recievers, including the one you have on several occasions, in the 18 years of working as an audio repair technician. With 2 speakers on the same channel you will draw double the amount of current thru the amp circuit than it was designed for. With 3 speakers on the same channel you will draw triple the amount of current and so on, and so on. I am really surprised that it played for more than just a few seconds with that many speakers on one channel. It must have been in really great shape to start with. I am sorry you did not know this before your party, it would have saved you some money.
Now the good news!
It should be able to be repaired. If all the speakers you had connected were really all on just one channel, you should have only one channel bad. This is a nice receiver as I am sure you must know, since you own it. It is worth getting repaired. As I have stated, I fix these for a living and I would expect the repair cost to be around $125 to $150 if it was taken to the service center that I work at. I can not be certain what another shop would charge, but this is a pretty good estimate considering I do not have it right in front of me to troubleshoot. Some shops are more honest than others, and there is always the chance that there may be more damage than what I would anticipate, or even less damage than I would expect resulting in a cheaper repair.
If you want to take a crack at fixing it yourself I would be happy to guide you thru it, but you would need the proper tools as I stated above.
I hope that you have found this information helpful, and if so, a rating of "FixYa!" would be appropriate and very much appreciated. After all, it is the only reward we get for offering people like yourself this free information and help.
Let me know if you want to try and fix it yourself, or if you have any other questions I can help you with.
Dave
