20 Most Recent
Acer ASPIRE 4720Z-2A0508MI LAPTOP LCD SCREEN 14.1" WXGA CCFL SINGLE (SUBSTITUTE REPLACEMENT LCD SCRE... Questions & Answers
No picture on acer aspire 4720z
Try connecting it to a TV or monitor, if you get a picture on them the fault lies with the screen itself, if you still don't get any picture it may be a graphics/motherboard issue.
BIOS password reset
The only way to reset a bios password is to remove the CMOS battery. This is a watch type battery, normally model 2032. Not sure where it is located, but is normally underneath the keyboard, connected directly to the motherboard. Can be a pain to get to.
How to enable wifi in acer 4720Z
Acer Aspire 4720 has
a wireless button to enable/ disable the wireless communication on your laptop.
You also refer to
Acer 4750Z Manual for further information, if required.
Hope it helps! Good Luck!
CreativeTECH
The recovery disc that acer sent is rejected as a
try this way please.
1 Ensure all Data is backed up, all data will be deleted.
2 Please also ensure that all USB storage devices are removed before starting the recovery process
3 Restart machine
4 When your unit switches back on, wait for the ACER screen then hold down alt & tap f10 repeatedly..
5 Please wait a moment until prompted, -How would you like to restore?-
6 Please select -Restore system to factory default-
7 Enter your defined password or enter six zeros '000000'
8 Click ok
9 Please wait until process completed, this will take 45min - 1hour
ALL personal information on the C: Drive I.E photos, programs, music and documents will be wiped when the above steps are taken.
Files located on the D: Drive will be safe from the procedure.
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
