20 Most Recent
Sylvania SRCD227 27 in. TV/DVD Combo Questions & Answers
Sylvania tv gets thin line where picture should
The problem is in the circuit board, there are bad solder connections near the high voltage transformer and the vertical deflector ic. If you are handy with a soldering iron unplug set, remove the back cover, "several screws" and check the underside of the board on the right side, when in dought touch up with soldering iron.
Why does my t.v. automatically shut off after 15
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
How to connect a additional speaker
Hi my name is John. Welcome to FixYa. Look in the back of TV you will see plug jack, just plug speaker in. Thanks for choosing FixYa....John
When tv is pluged in and turned on it shuts of
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive High Voltage were detected.
I need the codes to program tv on the urc-3220
I can help you with your URC-3220 Universal Remote Control issues.
The
codes for Sylvania TV's are: 0054, 0030, & 0171.
For complete
instructions on entering the URC-3220 remote codes, please refer to my
posted Fixya Tip One For All URC-3220 Code
Entry.
I hope
that helps.
_______________________________________________
One For All URC-3220 Manual
One For All URC-3220 Code List
Entry
Search
One For All URC-3220 Reassign
Key
Tv won't stay on
check the power cord and make sure it hasn't accidentally been cut or if its detatchable make sure its all the way in
Help
Move anything magnetic or any sound producing electronics away from you television. This includes stereo speakers or alarm clocks. Give your TV 30min. to 1hr. to cooldown completely and see if that fixes your problem.
TV does not start
There is problem in your Display. It does not run when it becomes hot.
VHS carriage stuck
THERE IS A SENSOR SWITCH THAT TELLS THE MACHINE THE TAPE IS LOADED ... SOUNDS LIKE IT IS STUCK.
PROBLEM IS ACCESS WITH COMBO'S. THEY ARE A PAIN TO GET AT. THE WHOLE BACK COVER TO THE TV MOST OF THE TIME HAS TO BE REMOVED,...
I KNOW ITS NOT MUCH HELP BUT THE MANUFACTURES KNOW THAT... HOPE YOU CAN GET TO THE TRAY INSIDE.
Joe_Rex
DVD player problem
You may have had a brief power outage you did not know about. Then the DVD player needs to be unplugged from the wall and started up again or your lens may need to be cleaned
Because your dvd player is only made to play region 1 discs and vcd's are region 2. You need to buy a dvd player which will play all region discs or is rated region 0 which is the same.
www.dvdenergy.com/index.htm
Sound but no picture
Is hard to tell what might be happening but the set has wires coming from the chassis to the crt board,backtrack your steps and check the conectors,ussually they can only fit one way and can not be forced in,make sure they have not been switched and stay away from the thick red lead coming from the output transformer to the back of the picture tube,it has high voltage and it can hurt a grown up man easily,the crt board in the neck of the picture tube nneds to be pushed in all the way,just checked that is in and if you have to remove it make sure you pull straight out and do not twist it because one of the pins in the crt might break,if you took it out before just check that one of the pins is not bent.Let Us know if you need more information.
