20 Most Recent
Uniden Bearcat Pro PC68Elite 40-Channels Base CB Radio Questions & Answers
How to clip and tune
why do you want to clip and tune a radio? Clipping the diode will make the radio modulate higher and unrestricted but if you take that radio and turn the power down to 2 watts give variable 4 a full turn to the right and open the modulation pot it will sound a whole lot better then if you clipped it. when you clip a radio you create a splash box that wipes out all channels lose by and the others will also be effected. the diode you want to clip is D-11. but I advise you not to.
Have a uniden pc 68
Could be audio chip.
- Insert external speak jack into pa port.
- Turn volume down
- Switch cb/pa switch to pa
- speak into mic
if you are getting audio from speaker ......chip is fine.
Peak tune
take it to a cb radio repair shop ,tell them to peak and tune to its max
D104-M6B WIRING FOR A UNIDEN 880 RADIO DIGRAM
Here is the wiring diagram for connecting a D104-M6B microphone to a Uniden 880 radio:
- Shield: Connect to pin 1 of the microphone jack on the radio
- White: Connect to pin 2 of the microphone jack on the radio
- Red: Connect to pin 3 of the microphone jack on the radio
- Black: Connect to pin 4 of the microphone jack on the radio
It's important to note that not all Uniden 880 radios are wired the same way. If you're unsure about the wiring on your specific radio, it's best to consult the manual or contact Uniden customer support for assistance.
