20 Most Recent
Fuji Zoom Date 60 35mm Point and Shoot Camera Questions & Answers
Camera not working-please help
No promises but if you take a roll of film that is already light fogged etc. and load it into the camera. Let it wind as normal. Now we need to work quickly: Press the rewind button. While it is winding OPEN THE BACK. It won't rewind very long because very little film is out of the cartridge so be ready. This will fogged a bit of the film but it does seem to clear the error. You can still shoot the roll if you just skip the first few shots.
Busted
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Fuji disposable camera
if you have the negative, you can ask to make another disk. try to open the disk in another computer. ask the place that made the disk if they have the information on their computer.
E4
Try changing the battery and reloading the film. You can try emailing fuji as well. If these don't work take it to your local camera store to send away for repair, or a new digital camera.
E2 Error Messagg
Dear Haley
Perform the following steps:
- Power off the camera.
- If you have a memory card in the camera, remove it.
- Remove the camera's batteries, then wipe the battery contacts with a soft, clean cloth.
- Reset the camera.For this
refer to your camera's User's Manual.
- Reinstall the batteries.
- Power on the camera.
This should work.please rate this solution.Thank you.
Shutter
sounds like the lil motor that is in charge of opening and closeing the shutter might have shorted out causing it to stick, or it could have just simply burnt out or striped the lil gears on the motor. If the shutter moves alil bit i would say you probably have a short in the shutter motor.
In my fuji frontier 370 error 2503 and w2411 is coming
The "W" indicates that it is a recoverable error. The "24" indicates that there is a problem in the paper feeder. The "25" indicates that it is a laser printer problem. Looks to me as though you have a paper jam.
2/13/2024 7:57:44 AM •
Fuji Cameras
Answered
on Feb 13, 2024
Sensitive Command Dial on Selector Button.- S9800 Finepix - any ideas what's wrong?
If the command dial on your Fuji Finepix S9800 camera is overly sensitive, making it difficult to select items on the menu or adjust settings, there are a few steps you can try to address the issue:
- Clean the dial: Sometimes, dirt or debris can accumulate around the command dial, affecting its sensitivity. Use a soft, lint-free cloth or a small brush to gently clean the area around the dial, removing any particles that may be causing the sensitivity issue.
- Adjust the sensitivity settings: Check the camera's menu or settings to see if there are any options to adjust the sensitivity of the command dial. Look for settings related to "dial sensitivity" or "control dial response" and experiment with different levels to find the one that suits your preferences.
- Reset the camera settings: If the sensitivity issue persists, you can try resetting the camera settings to their default values. Look for the "Reset" or "Factory Reset" option in the camera's menu and choose the appropriate setting. This will restore the original settings and may help resolve any software-related issues.
- Contact customer support: If none of the above steps resolve the sensitivity problem with the command dial, it may be worth contacting Fuji customer support for further assistance. They can provide specific troubleshooting steps or advise you on whether the camera needs to be inspected or repaired by a professional technician.
It's important to handle the camera with care while attempting any adjustments or cleaning. If you are unsure or uncomfortable with the process, it's recommended to seek professional help or take the camera to an authorized service center to avoid any potential damage.
6/18/2023 4:43:48 PM •
Fuji Cameras
Answered
on Jun 18, 2023
Camera fault
Check batteries and the terminals that connect to your batteries. Often the contacts get corroded because batteries have acid in them.
8/13/2019 10:01:32 PM •
Fuji Cameras
Answered
on Aug 13, 2019
