20 Most Recent Fuji MX-1700 Zoom Digital Camera Questions & Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Fuji MX-1700... | Answered on Dec 13, 2010
This can happen in two circumstances if the memory card is defective or the serial number of the card is not matching please try to format the card from the camera if you are unable to format it then remove the card from the camera and try to format with a card reader if the problem persist then replace the card.
Fuji MX-1700... | Answered on Nov 28, 2010
Hi there ,
remove the card clean the card pin and card slot in cam by a napkin. then try . if the same msg come then format the card and try again. If again same msg then change the card use new . Becouse every card have a limited snaps. For exam : 0001 - 1999 is life time camture capacity. if your full fill then the camera shown card error. Becouse when a card manufaturing the company fixed a total use capacity, so if that cross the msg with come that CARD ERROR.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Fuji MX-1700... | Answered on Jan 31, 2010
Lens cover is easy to open. Two opposite side of lens cover can be press slightly and pull to opposite direction. Flash may not work for so many reason. primarily, low bat power, then bulb is busted or micro wire is lossen or no contact. lastly your circuit maybe not in perfect condition.
Fuji MX-1700... | Answered on Sep 18, 2009
Any small distortion to the case will jam the dust shutter mechanism, as will dislodged dust and dirt. Remove the battery and carefuly remove the case screws. DO NOT LOSE. Lift off the front cover, take care with the top control knob and on/off switch as there are dust shields that may tear. This reveals the dust cover mechanism on the front of the camera. Dust off with an air-duster or soft spotlessly clean (new) paintbrush. Check a narrow ribbon cable is plugged-in at the front as this powers the cover motor. Gently guide the case around the top rotary control & on-off switch and line-up the circuit board beneath the rotary switch. Do not force anything together. Lightly re-assemble without screws and insert the battery - you cannot make this test without the cover-on as the case supports the switches needed to control the camera. Check that the cover operates correctly or is jamming on the case cover at the front where the shutter moves. If all OK replace the screws, else gently straighten the case with your fingers. This has happened several times to mine and cleaning it/lightly straightening the case cover always make it work again.
Fuji MX-1700... | Answered on Oct 06, 2008
No send it back they are the only people that will deal
More over - the likely cost will be very near the cost of a new high spec camera.
Fuji MX-1700... | Answered on Jul 21, 2008
First, ensure that both computer and camera are turned-off when you connect the two. Next, ensure the your serial port is not servicing another application.... In my case the Hot-Synch Manager for my Palm Organizer conflicted with Picture Shuttle. I simply exited Hot-Synch Manager and the Picture Shuttle worked as promised. I hope your fix is as easy...
Fuji MX-1700... | Answered on Nov 07, 2007
Check CD PDF File
Fuji MX-1700... | Answered on Oct 23, 2007
How about you mail in the rebate for a free USB adapter or Floppy disk adapter from Fuji Film ? The link is http://204.178.120.64/FREEFD.PDF Hope that helps!
Fuji MX-1700... | Answered on Sep 04, 2005
Use the manual set up ( the small camera icon with the "M" next to it. Play around with the flash settings and set your flast to night. Check out the manual on this feature. I just got my 1700 last week. The Halloween photos were a lot of fun. Its also my first digital camera and there is a lot to learn. I read every thing I could find on the web prior to my purchase. I felt the MX1700 was the best value. So far this camera has met or exceed all my expectiations.
Sounds interesting - what does it mean ?
Fuji Cameras | Answered on Dec 24, 2019
Follow the "instructions" in the "manual"
Fuji Cameras | Answered on Sep 19, 2019
Check batteries and the terminals that connect to your batteries. Often the contacts get corroded because batteries have acid in them.
Fuji Cameras | Answered on Aug 13, 2019
Ebay or Fuji, possibly ?
Fuji Cameras | Answered on Jun 20, 2019
This query does not appear to relate to any model of camera - are you sure you have posted it in the correct forum ?
Fuji Cameras | Answered on Jun 07, 2019
Fuji MX-1700 Zoom Digital Camera Logo
16 questions posted
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
Fuji Cameras
  • Fuji Cameras
Most Popular Question
error code se
  • Cameras
