20 Most Recent Fuji FinePix F700 Digital Camera Questions & Answers
Internal battery or capacitor may be bad and not holding charge to keep settings.
Fuji FinePix... | Answered on Jul 05, 2017
You may download a copy of the manual here.
Fuji FinePix... | Answered on Apr 22, 2013
Follow the instructions on page 15 of the manual.
Fuji FinePix... | Answered on Dec 20, 2012
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Fuji FinePix... | Answered on Dec 10, 2012
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Fuji FinePix... | Answered on Feb 27, 2012
Go to this website for possible solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fuji FinePix... | Answered on Nov 04, 2011
Are you check ISO setting are these taken on? Noise is when the ISO is turned up too much. I had a look on DPreview for you camera, but couldn't find it. Looking at this one ISO Sensitivity / Noise levels I'd say anything over ISO400 is "too much" in this case.
Could be a slow shutter speed. Try using a hard mount of some sort. Steady your camera against something solid like a table or a wall.
If the problem isnt solved, could be some CCD wrong; when a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Fuji FinePix... | Answered on Aug 12, 2011
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Fuji FinePix... | Answered on Apr 09, 2011
Hi.
Take pictures, then try downloading the pictures onto a computer. If the haze and lines appear in the picture, the faulty part is the CCD image sensor located inside the camera behind the lens. If the lines do not appear the problem is the LCD display unit or the cable to LCD.
Diagnosing the problem will help you to get a more accurate quote on repair.
About the repair, first contact Fuji using the numbers below, verify warranty status and get a quote on repair.
Contact USA: Fujifilm: Support
UK: Contact Fujifilm UK
AU: Fuji Australia - Contact
Asia: Asia - Fujifilm
Rest of the World: Support ' Fujifilm Global
You can also get a quote on repair from a third party service here:Repair
Regards.
Ginko
Fuji FinePix... | Answered on Mar 28, 2011
I have had the same problem with my F-700
After calling Fujifilm Custom support here in Spain, I've noticed that camera series had a common failure at CCD SENSOR, NOT THE SCREEN.
IF THE PROBLEM IS CCD (IMAGE SENSOR) FUJIFILM WILL REPAIR IT FOR FREE!!!!
EVEN IF GUARENTEE IS OVER
I AM NOT KIDDING. I'RECEIVED A MAIL FROM FUJI SPAIN ABOUT THAT
ALSO CHECKED THAT AT FUJIFILM USA THEY REPAIR IT FOR FREE
I guess the problem is CCD (at least in mine) because:
1- Started with intermitent colour distorsions (dissapearing from time to time)
2- The problem became more frequent as time passed by
3- THE IMAGE IS PERFECT WHEN I PLAY PICTURES FROM THE MEMORY CARD
GOOD LUCK !
Regards,
Ron
Fuji FinePix... | Answered on Mar 22, 2011
You should be able to goto any camera store, and they should have it as accessories. If not you can always go on www.ebay.com and search for finepix f700 adapter.
Fuji FinePix... | Answered on Mar 07, 2011
That depends on the cause of malfunction. If the lens shaft is broken, there is little you can do. Anything mechanical is hard to fix. What you can do is carefully open up the camera and see if there are any leads or wires fractured, and if there are solder them back together.
There are many electronic repair shops which could fix the camera for you for a small price, if possible.
Fuji FinePix... | Answered on Mar 01, 2011
This post is 10 months old I hope you have solved the problem, if not what I first expect is the memory card is full and the camera has defaulted to internal memory and it is also full. I would suggest downloading your pictures to the computer
Fuji FinePix... | Answered on Dec 26, 2010
yours is a broken CCD-chip - like ours.
hardly any good-used for the F700/710/810 avail anywhere
another new (used) camera is my best advice - repairing a busted CCD aint worth your time / money / efforts.
Try to clean the lense with a soft cloth. But before you wipe it, breathe out through your mouth into it to create a thin film mist then wipe it.
Fuji FinePix... | Answered on Oct 07, 2010
Fuji FinePix F700 Digital Camera Logo
94 questions posted
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
fine pix f700 lcd shows only
  • Cameras
