20 Most Recent Fuji FinePix E510 Digital Camera Questions & Answers
I re-formatted my camera and
Yes, cards do become unresponsive sometimes.
2/3/2011 4:47:53 AM • Fuji FinePix... • Answered on Feb 03, 2011
Finepix E510 zoom error
What is the zoom not doing tonight?
1/31/2011 2:44:02 AM • Fuji FinePix... • Answered on Jan 31, 2011
NO FLASH
Please check the setting of your flasher. Please set it to manual
1/27/2011 10:51:45 PM • Fuji FinePix... • Answered on Jan 27, 2011
Lost the cd rom
You can download software and the manual for your FinePix E510 from
http://www.fujifilmusa.com/support/ServiceSupportProduct.do?prodcat=789907
let me know if you have any other questions. Thanks.
1/25/2011 9:31:26 PM • Fuji FinePix... • Answered on Jan 25, 2011
Card not initialized
I'm going to give you a diagram to help you with this problem. All new memory cards need to be formatted or initialized before use. If the memory card is not formatted it may work the first time but not without problems once pictures are down loaded to the computer the BIG problems begin.
The memory cards need to be cleaned and formatted in the camera they are going to be used in to work properly, it's not the camera it's the card that needs to communicate with the camera.
Here is the diagram
12/30/2010 12:59:24 AM • Fuji FinePix... • Answered on Dec 30, 2010
Comes on but gose back off
Having gone over a month with no response, I assume it was just a battery problem.
9/11/2010 4:36:16 AM • Fuji FinePix... • Answered on Sep 11, 2010
Zoom error comes up on the screen. Lens will not
Could be a result of impact or dust that worked its way in there, it is actually easier than one can imagine.
Camera repair will fix this problem. A reliable company is Teleplan Camera Repair, they offer a free immediate online quote and include a camera cleaning as part of the repair.
Do not force the lens in or pull it out for you will further damage the lens assembly mechanism.
7/22/2010 7:53:28 PM • Fuji FinePix... • Answered on Jul 22, 2010
Does this camera have an internal memory ( stores
In the menu, there should be an entry for "copy" giving you the option to copy the internal memory to a memory card.
7/7/2010 1:09:50 PM • Fuji FinePix... • Answered on Jul 07, 2010
My Finepix E510 come up with card error. I have
You may need to format the card in the camera. This will erase it so download any pics first using a card reader.
7/4/2010 6:21:51 PM • Fuji FinePix... • Answered on Jul 04, 2010
My E510 camera won't turn on
It doesn't sound like you would know what to do even if you could get the camera open so please, don't try. A hard reset may not work but, here's how to do it. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on. You may also have a lens problem. Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
6/8/2010 1:23:37 PM • Fuji FinePix... • Answered on Jun 08, 2010
From where I can buy memory card for finepix E510
The Fuji Finepix E510 takes a memory card type called "xD Picture Card". You can buy it most retail stores, but you'll save a lot of money buying online.
The Upgrade Place has low prices and a Camer Memory Finder Tool. See the capacities available and click to buy xD Picture Cards at discount prices here: FujiFilm FinePix E510 Memory Cards
5/17/2010 3:29:00 PM • Fuji FinePix... • Answered on May 17, 2010
On the screen the problem
The zoom motor is your issue now what you can try is taking the batteries out then gently push the lens back in if the lens does not give any play then stop and take the camera to your nearest camera shop.
Thanks I hope this does help please do click on the accept button for my efforts. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
5/17/2010 3:05:24 PM • Fuji FinePix... • Answered on May 17, 2010
4answers
PROBLEM WITH FUJI FINEPIX E 510
So if you adjust the brightness up or down it stays the same- is that right? Looks like a component failiure, if nothing happens. You will have to check out Fuji for repair costs -can be pretty heavy
3/25/2010 2:11:14 PM • Fuji FinePix... • Answered on Mar 25, 2010
You need an XD memory card. You can get them from almost anywhere, photo, computer and electrical retailers including ebay.
3/20/2010 8:26:06 PM • Fuji FinePix... • Answered on Mar 20, 2010
Fuji FinePix E510 Digital Camera Logo
76 questions posted
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
re formatted camera
  • Cameras
