20 Most Recent
JVC GC-A33 Digital Camera Questions & Answers
I have problem to jvc
'MGI photo III se' is, I believe, software, not a driver as such. Are you sure that the drivers you have installed are compatible with your OS?
How to transfer photos from
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
I cannot import the pictures off of it ive down
Consider NOT connecting the camera to the computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
I AM NAVEED MUJAY JVC GC-A33 DIGITAL CAMERA KAY
are you looking for a software that can recognise your digi cam?
if yes then it is compatible with below mentioned OS only,
Windows 98/98SE/Me/2000
let me know if you need any other suggestion.
