20 Most Recent Jwin JXCD3250 Classic Style CD/AM/FM Boombox Questions & Answers
The remote for my radio/cd player won't work any longAny suggestions? The model is: jWIN JXCD3250 Classic Style CD/AM/FM
Remove the batteries, clean the battery terminals with rubbing alcohol and Q-Tips and replace the batteries with new ones, if no! I would suggest you have someone look at it, usually find bad solder connections that need touch up.
3/8/2012 7:25:47 PM • Jwin JXCD3250... • Answered on Mar 08, 2012
Looking for Data sheet this cassette / boom box sound player JWIN JX-CD414.
There isn't one. This is disposable throw-away junk made in China for 400 Rupees. As I told you, there is only pictures and a review. Take it to your local street market electronics vendor and ask him to fix it. https://www.fixya.com/support/t29943218-jwin_jx_cd414_looking_data_sheet https://www.google.com/search?q=JWIN+JX-CD414+data+sheet ..
1/2/2024 10:23:56 PM • Jwin Audio... • Answered on Jan 02, 2024
Have had this JWIN model JK-777 turntable/am-fm/cassette/cd player unit. It won't power on now. Checked the outlet, no problems there. Does this unit have a fuse?
1. It's more likely the problem is a broken power cord or dirty power switch. If you've been in the habit of yanking the cord to unplug the unit instead of pulling directly on the plug, or somebody tripped over the cord, the power cord is probably broken right at the plug. 2. Changing a blown fuse without finding and repairing the fault that blew the fuse will only give you another blown fuse. It's not like the old farmhouse with too many things plugged in on the same fuse... A blown fuse in audio equipment is usually the result of a shorted speaker driver transistor. The transistors come in pairs; if one is bad the other has been overloaded and should be replaced also. That's a job for an electronic technician.
11/22/2017 6:52:53 AM • Jwin Audio... • Answered on Nov 22, 2017
0answers
Its plays at a white screen how do i fix it ?
Hi, Your head gets cracked for that, you must call a technician and let the technician do his stuffs.
7/2/2014 4:37:34 AM • Jwin Audio... • Answered on Jul 02, 2014
My mp3 wont play songs that i put
My jwin jx-mp101blk quit when I deleted the folders in it to make room for saving stuff. It still works as a memory stick, but won't play. What are the needed files?
11/14/2012 9:31:27 AM • Jwin Audio... • Answered on Nov 14, 2012
Hi i have a jwin jx cd6700 system and im trying to
not possible. unless you connect through head phone. it takes two kinds of different cables. better to download of internet music to cd
5/7/2012 8:06:53 PM • Jwin Audio... • Answered on May 07, 2012
How to i format music to mp3
You need to use a video converter to deal with the format problem.Go and have a try for this one which I have used for long,it will help you easily convert the music to Mp3.here is the link for this good video converter.
5/4/2012 2:36:28 AM • Jwin Audio... • Answered on May 04, 2012
How do i lock the controls on my Alba MPK8065BUK mp3 player ?
hold the upper right key and it will say "hold" do the same to unhold
2/22/2012 9:04:17 AM • Jwin Audio... • Answered on Feb 22, 2012
I have broken a record
It can be purchased from the link below.
http://www.lpgear.com/product/JXCD3400.html
7/27/2011 11:52:38 PM • Jwin Audio... • Answered on Jul 27, 2011
Hi my screen won't turn
damaged screen or cables connecting to the screen ... will prob need replacing
5/29/2011 3:10:47 PM • Jwin Audio... • Answered on May 29, 2011
It say file system error
File System Error meaning that you have a corrupted program. Re-installing the program is the only solution. Unfortunately, all files will be deleted.
It would be best to contact the manufacturer and have them re-program the device with the version that would work best.
Good luck and have a good evening!
1/23/2010 12:04:15 AM • Jwin Audio... • Answered on Jan 23, 2010
1 questions posted
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
k24674
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jwin Audio Players & Recorders
Most Popular Question
remote radio cd player won 39 t work
  • Audio Players & Recorders
