There should be any shorted components, at its main power regulator section. Check and replace it. Products powered by electricity
should be serviced or repaired only by experienced professional technicians.
Any attempt to service or repair the product by anyone else could result in
serious injury or death. If
you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact
the nearest service centre.
You can access the on-screen menu by pressing the Vol+ and Vol- buttons together on the front of the TV . Alternatively use a remote and press Menu to access the menu (not all low end remotes will match the feature) An exact replacement remote is available here: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12878563535890&smodel=MS3252S&brand_pn=MAGNAVOX_MS3252S . Then use the channel up and down buttons on the TV to select menu items. If using the remote use the play, fast forward, fast rewind back and pause to go through the menus. Press Menu to go back one level in the menus.
Once you have the menu up, go to the bottom of the list to Install. Select Tuner Mode (the options are Antenna, Cable and Auto) and make sure that is set correctly. Next select Auto Program to look for all available channels or Edit Channels to change the channels you will see when you change the channel with the Channel up and down buttons.
Please note that the TV only has an NTSC (analog) tuner and must be used with a set-top box to see any channels other than the remaining low power stations that have not switched to digital.
Once you have a new channel list, the TV will remember the last state it was in. (Please note that the A/V inputs are reached by pressing Channel up or down past the tuner channels.
Does your set have menu on front of tv if so press menu use your channel up & down bottons to move up&down menu go to video use your vol up & down to adjust set to off on cc. Also need remote go to Dollar store buy RCA 4 in one remote 5.00 works all tvs has code book with it your code probly 062.
If you dont here anything then it sounds like the switching power supply or the horizontal output circuits not starting up. this requires troubleshooting with a variac, as well as maybe a scope. If your not trained to work on HI Voltage circuits you should seek assistance with this repair. Theres HI voltage inside these sets even after they are unplugged for a while. sorry i couldnt be of more assistance.
Change horizontal driver buffer transistor's and capacitor's. 7461 7463 transistor's. Caps 2455 2405 near transistor's.
Please leave your email address, I will try to find the service manual for you.
Best regards,
Arpi
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
This is a question for Philips,the software might be corrupted or it might need to be updated and for that philips will have to send someone to do the update,I wouldn't be surprise if you are not the only one with this problem,give them a call 1-888-744-5477.Let Us know how it goes.
Remove the cover on the back of the tv. Look for swollen or leaking capacitors. They kinda look like batteries. If they are bulging or leaking then that is your problem. You will have to de-solder the old ones off. Then solder the new capacitors onto the circuit board. Capacitors will cost about 20 dollars and installing them isn't that hard to do. It will fix your tv 99% of the time. So it is worth a try!
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings. This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
