20 Most Recent Philips Magnavox 20MS233S 20" TV Questions & Answers
2answers
My tv won't go past channel 17
Please try this free Philips Flat Panel Television owners manuals, user guides & how to ... A B C D E F G H I J K L M N O P Q R S T U V W X Y Z ... 13" LCD-TV PF7835 - Philips 20" LCD-TV Product Brochure ... 13MC3206 - Magnavox TV/DVD Combination ...
tv.manualsonline.com/manuals/mfg/philips/philips_flat_panel_televis... - 674k - Cached
12/12/2016 3:44:26 PM • Philips Magnavox... • Answered on Dec 12, 2016
TV will respond to remote control
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing each button on it at a time; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
4/19/2015 6:19:00 PM • Philips Magnavox... • Answered on Apr 19, 2015
2answers
Turning off Closed Caption
Are you using a cable/satellite box or just basic cable service?
When you go to the menu what options become available to you?
If the following options are present-
smartlock
setup
cc
If not try to press both the volume buttons on the front of the TV at the same time and see if the above options become available.
If so use the channel down button on the front of the tv to scroll to "cc"
Once CC is highlighted use the volume + button until it says CC off.
If these menu options don't become available please reply what options are shown.
Good Luck.
11/30/2014 8:12:47 AM • Philips Magnavox... • Answered on Nov 30, 2014
Codes for magnabox
0038,0031,0025,0020. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
8/12/2014 6:29:03 PM • Philips Magnavox... • Answered on Aug 12, 2014
Need a Magnavox remote control
By an universal control that states on rear packaging model and brand name that your where using .
7/25/2014 1:17:13 AM • Philips Magnavox... • Answered on Jul 25, 2014
2answers
How do I shut off
hi,
For closing the Closed Caption option do the following.
1. Press the MENU button on the remote to see the menu.
2.Press the up arrow or down arrow until the CC (Close Caption) is highlighted.
3. Press the right arrow repeatedly until CC OFF appears.
4 .Press the menu button to exit.
Or, you also can set Closed Captions by pressing the CC button on the remote. Press CC repeatedly to select: CC-OFF,
ok
3/18/2014 1:06:26 PM • Philips Magnavox... • Answered on Mar 18, 2014
20ms233s tivo remote code
Try one of these (remote code) numbers to connect your remote to your Magnavox TV : 00051, 00054, 00802, 01198, 01254, 01365, 01454, 01856, 01866, or 02372
3/5/2014 3:03:42 AM • Philips Magnavox... • Answered on Mar 05, 2014
0answers
0answers
M3250 no power on
Check and replace damaged component/s at its main power regulator section circuit.
3/27/2013 5:01:29 PM • Philips Magnavox... • Answered on Mar 27, 2013
Give me the remote code for Magnavox 20MT4405/17
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
9/17/2012 3:39:41 PM • Philips Magnavox... • Answered on Sep 17, 2012
Lost access code number
If you means that you did forget the universal remote codes, these are the codes for Maganavox TV: 0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141 Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now.
9/16/2012 12:51:50 PM • Philips Magnavox... • Answered on Sep 16, 2012
I need codes for Magnavox
9/8/2012 3:44:56 PM • Philips Magnavox... • Answered on Sep 08, 2012
My remote control doesnt work
Check the remote control for its infrared emission. To get more details about how to check the remote control and to repair it if it found faulty, Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help. Pull up older posts there. Fault finding to remote controls and repair proceedings are given here in detail.
5/23/2012 8:56:51 AM • Philips Magnavox... • Answered on May 23, 2012
0answers
I have run into a sound issue with my Magnavox
There must be a problem with your amplifier check for busted fuse, transistor or IC on the audio section. It must be replaced to enable the sound.
11/8/2010 12:49:42 AM • Philips Magnavox... • Answered on Nov 08, 2010
Philips Magnavox 20MS233S 20" TV Logo
Popular Tags
90 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
  • Televison & Video
