20 Most Recent
E-Machines etower 566i PC Desktop Questions & Answers
I forgot to remove input
First, check your power supply fuse for damage and switch the power to standard. Disconnect power supply output port and check your output voltage. If nothing abnormal, turn off power supply, connect the output and turn it on to check the power on your PC
Regards,
12/14/2010 11:47:31 PM •
E-Machines...
Answered
on Dec 14, 2010
My machine has been taken over by a desktop
In order to get rid of this you will need to download some sort of anti-malware software. Some free ones you can use are Malwarebytes (works great) @
www.malwarebytes.org Alot of times these viruses will prevent you from going to any webpages so you may need to download them from another PC and put them on a disc or flash drive. If malwarebytes doesnt do the trick theres always Spybot S&D and also Trojan Remover (all of which are free)! You may need to boot into safe mode in order to run the scans. Generally you can get into safe mode by pressing the F8 key (tapping it a couple times a second) upon startup. Otherwise,
click here for further details about this virus.
Can i install a sata drive in an emachines etower
bad news there is no chance this is a realy old machine with
- Installed Memory:
32 MB (SDRAM)
- Operating System:
Microsoft Windows 98 SE
- HDD Size:
7.5 GB if you are still using this ancient machien then It realy is time to upgrade
I have an old emachine it has a regular phone
This is a PCI Network Card. It plugs into a PCI expansion slot on your computer. You will need to install the drivers for this network card to work properly.
How to install a network card
Some newer computers come with network interfaces built in - your
machine carefully for a socket that looks like a large telephone
socket with a
next to it. These are sometimes hidden behind a
flap or on the corner of your laptop next to the modem socket.
If you haven't got a network interface already on your machine
you will have to install a network interface card. These are
available to buy from the IT Service Desk.
- USB Adaptors simply plug into a USB port.
- PCMCIA Cards for laptops slot in a free PCMCIA slot on the
side of your machine.
- PCI Cards are a bit more fiddly and require you to open up your
machine.
- We advise that you use a USB adaptor for ease of installation
Instructions on how to fit a PCI network interface card.
- Shut down Windows and then turn the computer off and unplug it. Never
work in your computer's insides with the power on or the power cord plugged
in!
- Remove
the cover from your computer. There are normally a number of screws on
the outside of the case to remove. Put the screws someplace where they
won't wander off.
- Find an unused expansion slot inside the computer.
The expansion slots are lined up in a neat row near the back of the computer.
All new computers have at least three or four slots known as PCI slots.
- Many older computers also have several slots known as ISA slots. You can
distinguish ISA slots from PCI slots by noting the size of the slots. PCI
slots are smaller than ISA slots, so you can't accidentally insert a PCI card
in an ISA slot or vice versa. Figure 2 shows the different types of slots. PCI slots are white, ISA slots are black
- When you find the right type of slot that doesn't have a card
in it, remove the metal backplate from the back of the computer's
chassis. A small retaining screw holds the backplate in
place. Remove the screw, pull the backplate out, keep it in a safe
place in case you ever want to remove the network card.
- Insert the network card into the slot.
Line up the connectors on the bottom of the card with the connectors in the
expansion slot, and then press the card straight down. Sometimes you have to
press uncomfortably hard to get the card to slide into the slot.
- Ignored the little cable that came with the card, you can
chuck this in the bin. It is a Wake-On-LAN connector and isn't
required for your card to work.
- Secure the network card with the screw that you removed in Step 4.
- Put the computer's case back together.
Watch out for the loose cables inside the computer; you don't want to pinch
them with the case as you slide it back on. Secure the case with the screws
that you removed in Step 2.
- Turn the computer back on.
Please give a 4 star rating. we do this for free, the only reward we get is your approval.
Super drive
You can go to BIOS setup and check that CD drive is recognize there or not, If not then there must be some problem with CD Drive or connectivity of CD drive with computer, If it is showing there then you can follow this tutorial and change with the registry.
http://support.microsoft.com/kb/314060
Bios setup
To reset bios, turn computer off and remove side cover, remove coin battery from motherboard and jump appropriate pins on the motherboard to clear cmos. These pins can be found in the owners manual online at the E-machines website.
Have a new tv how do i get connected to my old computer
to hook the computer to the tv you do not need a disk ..basically you need to have a pretty good video card on computer so that it will have a hdmi video out ..and this way it will work on hdmi ..or if it has a tv slot ..use it ..and select the proper input on the tv ..If there is no image on the tv ...you have to go to the video settings ..and select to enable the secondary monitor or tv out..for some computers you can do this by pressing Fn and F5 or F4 or F7 ..(or ctrl = f....) ..and will enable it auto ..but ..it is best to make sure you have teh correct driver for the video card ..and after the connection being made with the cable ..and select the correct entry in the tv ...just go to the video card settings ..or click right on desktop ..and select properties and than display settings ..or ..settings ..and on the page where it shows the monitors..click on the secondary and enable it ..and select the way it will work ..(clone or extend display ..second one will make the monitor an extension and you can select different tasks for the space )
I have an eView 17f3 computer monitor that was
well that is 17,000 volts there 17kv and can be lethal .
CRT is cathode ray tube and 2nd anode is 17kv, 1kv per inch screen.. we use a chicken stick to discharge that.
one guy gut hit here and flew across the room ,hit head and next up paramedics deep.. not fun to see that. ive taking 600v but never again.
vaccum seal, why do that.???
send it to the , toxic lead recycle center, let them do the danger work
when I was only 16yo I worked in TV shop and I had do that "nnipp" that in the bud on all CRT sent off to refurb. (or toxic trash) (we sold them all here, you name it)
we had to remove the socket there find he glass bud there dead center and full PPE, and snap it with wire cutters and it sucks in air fast. later in military too on old radar scopes, i worked .
the vacuum inside is pure and prefect, zero gasses.
implosion hazard exists. a glass flies in the bounces out and hits you and then next up blind i one eye. leave CRT alone to the trained.
Hi i have emachine 8230 tower
firstly lets think why a Working pc would no longer BOOT. The boot process then. a pc starts the bios which POST's. this results in ONE BEEP which might be followed by messages(if you get several beeps then they are like morse code long/short and count out an error code). when you get your ONE BEEP the pc is working. when it then HANGS(appears to do nothing) its usually because of either a) the cd drive is duff so disconnect its cables. b) the hard drive is duff so disconnect its cables c) the hard drive hasnt quite died yet but has some very slow sectors and is making the Clackety Clack of the heads recalibrating every few seconds. d) there could be a a gpu card bios glitch and your pc is running but you just have a blank screen. some hints then 1) never start removing parts as that corrupts the CMOS(the battery backed up configuration for your BIOS) so you may need to clear your cmos. 2) never play with the idea of changing ram sticks as people usually end up putting them in any old slot(which may result in a non working pc). make sure a PAIR is fitted in slots 0/2 and a separate matching pair in 1/3 slots not in slots 0/1 which is two half pairs. Other factors. 1) a short circuit. your PSU has built in protection, if the psu fan(inside case of the psu) turns and kicks back and immediately stops you have a short circuit and its cuts the power to avoid a fire/meltdown, which could be caused by high wattage gpu(>60 watts) without its extra power cables fitted or wrongly connected front usb cables or removing a mainboard and fitting it into a new box where the board has its support posts NOT lined up with the holes fro the screws so the post is touching underside of the board circuits. hope some of that helps.
