20 Most Recent Alba DVD55 DVD Player Questions & Answers
4answers
When disc is inserted it says 'unknown disc'
one particular disc? or all discs?
Unplug for 5 minutes and re-try.
Thanks
1/20/2013 11:29:51 PM • Alba DVD55 DVD... • Answered on Jan 20, 2013
It is several years old,
It sounds optical lens might got thin layer of dust on its surface and causing problem in data reading on disc.
Take off dvd player's cover and clean its optical lens with good quality soft cotton bud gently then try to play disc.
Hope this will fix dvd player problem.
Thanks.
1/3/2010 7:04:44 PM • Alba DVD55 DVD... • Answered on Jan 03, 2010
I simply need to clean out dust or something from
Dust does not cause a crackling sound in DVD players. You either have a bad connection between the player and the amplifier/receiver, a bad preamp out circuit board in the DVD player, or a bad input circuit board in the amplifier/receiver.
You can figure out which one is the culprit if you have another amplifier/receiver system to test with. If the problem moves with the amplifier/receiver, then it's the DVD player. If it does not, then it's the amplifier/receiver.
12/13/2009 4:41:10 PM • Alba DVD55 DVD... • Answered on Dec 13, 2009
I have a region 2 dvd player and i want to play a
Some players are harder than others to do this but you may want to try here or here
9/13/2009 3:02:39 PM • Alba DVD55 DVD... • Answered on Sep 13, 2009
Permenant "Unknown Disk"
Hi and welcome to FixYa,
Initially, pls try and clean the laser optics with the use of a CD disc cleaner. Additionally, perhaps you can open the DVD and clean the inside with a can of compressed air. While it is open, you can also apply a bit of lubricant on the long metal rod that serves as guide rail for the lens carriage to move on.
Good luck and Thank you for using FixYa. Happy Holidays.
12/21/2008 8:41:51 AM • Alba DVD55 DVD... • Answered on Dec 21, 2008
Try cleaning the player with a DVD lens cleaner.
If you're adventurous enough, and the player is out of warranty, you might want to open up the player exposing the lens part. Then, try to eject and close the disk tray and see if the laser diode lits up (avoid staring at the laser light, it will ruin your eyesight! View it from the side not directly into your eye.)
Also check if the spindle spins a little. Or, with the top cover open (this magnetized cover serves to hold the disc firmly as it spins), insert a disc into the tray and close it. See if the spindle spins with the disc.
This problem points most of the time with either a bad laser or misalignment. If misalignment is the case, this could be fixed by carefully turning (very slowly...) a tiny potentiometer located near the laser diode (experiment with the best setting, mark each turn and try any disc with each turn. Be patient)
This fix is not for the faint of heart, and at your own risk. If you're not sure of what you will be doing, leave the servicing to a qualified technician.
12/21/2008 8:33:19 AM • Alba DVD55 DVD... • Answered on Dec 21, 2008
ROOT
Root Folder/ Directory refers to the main Folder which contains all the important informations and commands your player has. It is similar to your Root Directory in your PC -- Drive C:/ where all the system files are located.
Root Directory includes sub folders such as your player's Master Boot Record (MBR - very crucial, this is the boot operating system), music file directory, audio record directory, data files directory such as organizer and phone directory (if your player has one).
Root Directory is very important for your player's performance as it contains all the valuable informations and commands so your player would run under normal condition. Once everything was erased in that root folder, you'll render your player useless. So be extra careful when you upgrade your player's firmware as this erases all files including those the OPERATING SYSTEM in the root folder.
It is safe however to format within your player as this erases only your data files and music. Just to be sure, avoid formating your player in your PC's MY COMPUTER/ WINDOWS EXPLORER unless it is specified in the users manual.
Luckily, MBR are usually erased when you entered your player's SERVICE MODE and you choose to erase the Firmware using some special keys. So, as long as you're using your player as mentioned in your users manual, you're okay with it. If you doesn't know all about mp3 player repairs or upgrades, leave the SERVICE MODE or PLAYER RECOVERY to the technicians.
MANNY DE GUZMAN, JR.
aka "TECH DATA"
SoundMagik Home Studio
Manila, Philippines
Visit my website: http://mannydeguzmanartist.wetpaint.com
My talents/ modeling site: http//teenmodels2007.wetpaint.com/
My YouTube Channel "mannydeguzmanjartist":
http://www.youtube.com/user/mannydeguzmanjartist
My imeem.com social media channel "mannydeguzmanartist", where all my music editing, remixes, creations, and voice demos can be found: http://mannydeguzmanartist.imeem.com/
3/31/2008 1:42:13 AM • Alba DVD55 DVD... • Answered on Mar 31, 2008
Alba remote stopped working
Try replacing batteries.
10/20/2023 12:09:27 PM • Alba Televison &... • Answered on Oct 20, 2023
Hi There my Alba 16" tv has started running subtitles of what is being said on screen pressing the subtitle button on the remote has no effect how do i disable this please?
Second button from left side of handset bottom second row of your remote control turns subtitles on & off alba TV
10/2/2023 5:50:46 PM • Alba Televison &... • Answered on Oct 02, 2023
How to retune an Alba AELKDVD2288PK without a remote control?
All televisions need a remote control for advanced options. A new one is $17 on eBay or Amazon or the Remote Control website.
Genuine Alba AELKDVD2288PK TV Remote Control
eBay https://www.ebay.com > ... Save on Remote Controls ; DIRECTV RF-XMP RC66RX Universal Remote Control. $9.95. Trending at $16.98 ; NEW Replacement BN59-01259E Remote Control for Samsung Smart ...
Classic Replacement Remote Control for Alba ...
Amazon UK https://www.amazon.co.uk > Replacement-Control-AE... This Classic remote control is a replacement for the original Alba AELKDVD2288PK remote. The Classic remote will operate all the functions of the original ... £17.94 https://www.google.com/search?q=Alba+AELKDVD2288PK+replacement+remote ..
5/21/2023 6:35:14 PM • Alba Televison &... • Answered on May 21, 2023
I bought a secondhand 16 inch Alba tv. It says tv must be reinstalled and go to set up menu. How do I access set up menu?
Impossible to answer definitively without the model number off the rear label, but here are three manuals. They are all online. I hope you go the remote for it as access to the Settings is normally via the remote.
Alba ALTVDI711701 Instruction Manual
ManualsLib https://www.manualslib.com > ... > ALTVDI711701 View and Download Alba ALTVDI711701 instruction manual online. 17" HD Ready Digital LCD TV with built-in DVD player docking for iPod. ALTVDI711701 tv dvd ...
User manual Alba ASMKDVD19 (English - 32 pages)
Manua.ls https://www.manua.ls > Televisions > Alba Manual. View the manual for the Alba ASMKDVD19 here, for free. This manual comes under the category Televisions and has been rated by 1 people with an ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 56px;"> Rating: 75% · ‎1 vote
Alba LCD19880HDF User Manual - Page 1 of 34
Manuals Brain https://manualsbrain.com > ... > User Manual LCD19880HDF - read user manual online or download in PDF format. Pages in total: 34.
5/2/2023 3:58:26 PM • Alba Televison &... • Answered on May 02, 2023
Why does my TV keep turning off while I'm trying to return it
There could be a number of reasons why your Alba TV is turning off after just a few seconds. Some common causes include:
  1. Power supply issues: If the power supply to the TV is not stable, it can cause the TV to turn off. Check if there are any loose connections or faulty cables.
  2. Overheating: If the TV is overheating, it can shut off to protect itself. Ensure that the vents and fan are clear of any obstructions and the TV is not in a location that is too hot.
  3. Faulty remote: Sometimes, a faulty remote can cause the TV to turn off by itself. Try removing the batteries from the remote and see if the issue persists.
  4. Faulty hardware: If the TV's hardware is faulty, it can cause the TV to turn off. This could be due to a number of reasons, such as a defective power supply or a malfunctioning circuit board.
If none of these solutions work, it's possible that the TV is defective and needs to be returned for a replacement or repair.
2/26/2023 5:16:17 PM • Alba Televison &... • Answered on Feb 26, 2023
Need to chune in ALBA t.v {LCDWV16HDF} t.v channels without remote
Not possible. Purchase a controller via fleabay/amzunzun etc to be able to enter any menus.
9/26/2022 5:03:03 PM • Alba Televison &... • Answered on Sep 26, 2022
How can I connect a playstation 2 to an Alba TV?
No, it you don't have Composite Video connections, you can't. Alba is not a good make, it is a bargain basement brand from the 70s and 80s. Check Facebook Marketplace for something a bit more modern and HD.
5/11/2022 4:02:23 PM • Alba Televison &... • Answered on May 11, 2022
Alba DVD55 DVD Player Logo
Popular Tags
22 questions posted
Top Alba Televison & Video Experts
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alba Televison & Video
Most Popular Question
region 2 dvd player want play
  • Televison & Video
