20 Most Recent
E-Machines T3092 PC Desktop Questions & Answers
Find mobo speaker connector
Front or Rear connections? Open the case, it's at the rear of the Mobo. It will be enclosed in the connectors. If you have lost a channel, it may not be easy to repair. A sound card is a option.
HOW DO I STOP EMACHINE FROM USING DIALUP TO GET TO INTERNET
Open Internet explorer click on toolsClick Internet optionsSelect the Connections TabUnder Dial-up and Virtual Private Network Settings Select each available connection and click Remove.Click Apply and OKNow you will not get the dial up prompt while connecting to the Internet.._______________Note: You can also open Internet options directly from Control Panel..
I have a Shure mic
Which particular mic?
Go through the signal chain. Mic to mixer to pc.
All the level changes are suspect, what busses are you using...
e.g.
mic to channel 1 on mixer.
trim on mixer 1
fader on mixer 1
L/R balance
fader on L/R
which output from mixer are you using
Then the windows mixer (start/run "sndvol32.exe")
adjust the volume, WAVE, mic, etc.
My first instinct is the windows mic level.
Need a replacement power supply for e machine
Hello sbfca,
Here are a couple links to power supplies that will work for you:
Any of these will work with you factory system. If you have installed a better graphics card or additional drives, you may want to increase the wattage. I have had good experiences with both of these sites and the ratings and reviews for the hardware are very helpful when making your final decision. Post a reply if you need any other assistance with your power supply or please rate this solution if you found it helpful. Thanks!
Edward
Hi! Well,I dl the chipset
The answer has to be in the connection. Your XP doesn't have the right driver set
up for the LAN or 10/100 Set up. Try removing the driver and rebooting the system.
Also once in windows try going to start -run and type in command. Once this widow is open type in >: ping www.wnd.com and see if it 'pings' the web. if not then the issue is back to the driver - modem etc.
Do other pc's access the web on the exact same set up? If yes consider validation and then try again.
You can always re-install but I think you need to check the drivers for the
net work card driver. Good Luck
Gary @ Fix Ya
I HAVE TRIED TO INSTALL
Okay,
Have you tried the
nvidia.com website, just because its
Emachines does not mean that
nivdia cannot help. They have a
genric driver that actually installs and works for
different versions of there
chip sets.
Give that a try.
Also keep in mind
Emachines is gateway.com as well.
if you have any questions please ask.
also a reminder you left no model number or nothing for us to examine here so try
nvidia.com first.
Thanks and please do click the accept button for my efforts. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Lost sound upon reload. how to restore
You will need to download the drivers for you system. Because I do not know the windows version that you are using I am unable to assist you in finding the download, but google search something along the lines of (driver download for e-machine T3092 Windows "")
Sound card
ok find out what sound card it is then go looking for the driver or you can get a program like driver pro and it will check then find then install the sound drivers for you hope this helps
Replaciinf chipset
are you just replacing the motherboard or are you replacing the north and south bridge chip both guides can be found on youtube hope this helps
When I turn it on, I only get a screen saying that
If you defragged it then it must have started. I would advise you to save all files you do not want to loose if you can get it started. Now ask yourself this question. What hardware or software changes have you made recently? Have you installed any hardware or downloaded any software at all? If so, that is your problem. Remove whatever you installed if possible, Try starting in Safe Mode.
Re-installation on T3092
You must enter a computer name. It must be 15 characters or less with no spaces. Use only letters and numbers.
Only the description is optional.
