20 Most Recent
Philips VR620CAT VCR Questions & Answers
How get menu to show language option
Press the vcr button then press menu,press the play or stop button to select vcr set up,then press the fast forward button.Press play or stop button to select language,then press the fast forward button.Press the play or stop button to select English or Spanish.Then press the status exit button.Hope this helps.
Philips manuals
Most VCR's have manual tracking. Generally it will use a set of keys on the remote used by another function. Often the channel up down keys! This will also apply to the controls on the video itself.
Bad tracking is also caused by dirt one the heads or tape path. So clean the machine first before adjusting the tracking.
Philips VCR model VRX364AT. Remote controller
Internal damage to remotes is common, generally most are not worth fixing. If you look on the remote you should see a model number for it. Put that into google and see if the remote is cheap, or if not it might be better to attemp repair.
I can't correct the tracking on my philips vcr.
your tracking may not be a tracking problem it could be dirty heads open the vcr and use a piece of clean notebook paper and slightly press against the head(round cylinder) while manually turning the head it will pull the dirt off the head and clean it do not use any cleaner as it causes film on the head, other solution is your auto tracking is off and can be adjusted by slightly turning the arms that hold the tape around the head while it is playing and watch the picture till it is clear then stop
Trying to find remote codes for model vr620cat
Not surprised, none match the codes for Philips VCR!
Here's the correct ones: 1009, 1033, 1065, 1066, 1067, 1100, 1133, 1145, 1162, 1163, 1164, 1200, 1207, 1239, 1240, 1243.
Remember some codes may work parts of the VCR and not all, so you might have to try several or maybe all of them to get the best match!
Error 2 on Front Panel
I'm not sure if this is a solution, but it cleared up the problem for me. It turned out there was a loose paper label for the cassette that got stuck inside the VCR with the cassette.
I had to take off the top of the VCR by removing the three screws. I then removed the jammed loose paper and then was able to get the cassette out. The flashing number 2 (whatever that means) went away. The machine seems to be working fine now.
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
