20 Most Recent Olympus Camedia C-460 Zoom del Sol Digital Camera Questions & Answers
2answers
How to view movies on PC
Right-click on the movie and choose the player you want to open it with. You may need to download one if you don't already have one on your computer. Quicktime is a good choice...it's a free download at apple.com.
9/15/2022 2:03:55 AM • Olympus Camedia... • Answered on Sep 15, 2022
How do i trun the flash off at night
Press cursor-right (marked with a lightning bolt) to bring up the flash menu. Press cursor-right to cycle through the flash options. The one you want is the lightning bolt in a circle with a slash through it.
6/1/2012 4:23:55 PM • Olympus Camedia... • Answered on Jun 01, 2012
Buttons do not work
You can upload pics without doing anything except turning it on.
You can turn it on, plug it in and use either media player or picture viewer or equivelant program to sync the device. Most these programs have a sync option that will take all media off camera and put it on computer. Unless you are using a sim card and have a card slot on your pc
8/13/2009 12:53:08 PM • Olympus Camedia... • Answered on Aug 13, 2009
I need basic set up as my daughter has been using
Pull battery and the memory coin-type battery out of the camera, wait a few minutes and reinstall.
It should go back to default settings.
6/18/2009 9:44:05 PM • Olympus Camedia... • Answered on Jun 18, 2009
Camedia C-460
http://olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=956
Here is the link to the Olympus website where you can download a free copy of the user manuals for the camera.
5/14/2009 5:57:05 PM • Olympus Camedia... • Answered on May 14, 2009
How can i use the camedia c-460 as webcam on mac
Unfortunately there is no camera in the Olympus product line that has webcam capability. The only reason you would connect the camera to the computer in the first place is to download the photos from the picture card to your MAC hard drive.
5/14/2009 5:54:57 PM • Olympus Camedia... • Answered on May 14, 2009
Can't reuse the smart card
try formatting the card using the camera menu... looks like a tomahawk
4/7/2009 8:38:02 PM • Olympus Camedia... • Answered on Apr 07, 2009
Memory card will not lock in place on camera
well even if u get inside probably u will not be able to fix it because it´s pretty normal for the xD socket to brake and needs to replaced. anyway after u remove all the screws just pull it hard, because sometimes the cover is glued to the mainboard, the socket is on the mainboard, be careful once u open it can have loose parts from the xD socket, if u can get it t work, after just glue all that because it brakes a lot, don´t use 3 sec one because will damage the socket.... if it´s under warranty just send to the repair centre they will fix it for free....
2/7/2007 4:58:06 PM • Olympus Camedia... • Answered on Feb 07, 2007
2answers
How do I transfer my pictures from my Olympus C-220 Zoom camera to my PC?
Yes, there are two ways 1. Connect the camera via USB, and look in File Explorer or 2. Take on the Media Storage Card and put it into a Card Reader attached to the computer. https://www.manualslib.com/manual/301217/Olympus-Camedia-C-2-Zoom.html?page=31#manual ..
3/27/2024 9:57:45 PM • Olympus Camedia... • Answered on Mar 27, 2024
2answers
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period. Always charge sets of batteries (2 or 4) together. Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set Don't use barrettes from different sets or brands together. I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away. Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad. Check you are using a charger for NiMH batteries. I would try another set (new) because buying Alkaline is also not cheap. I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger. Never use manganese (Zinc-Carbon) batteries in electronic devices. These batteries are only to be used in flash lights.
12/7/2016 8:12:01 AM • Olympus Camedia... • Answered on Dec 07, 2016
How to use zoom on c-860L
This 14 year old camera, does not have a zoom lens. It has a 5,5 mm lens, giving it a angle of view of about a 35 mm lens of a Full frame camera. However, you should be able to zoom digital 2 times. I can't find a manual, to help you on this, but the quality will be the same as cropping into a frame on your computer. So if you do put the pictures on a computer, you also can "zoom" in to the parts you want. Be aware a 1 megapixel camera, does not offer that much of detail.
10/27/2014 11:34:04 AM • Olympus Camedia... • Answered on Oct 27, 2014
Zoom error olympus
Lens is out of possition and stuck.
7/31/2014 7:19:31 PM • Olympus Camedia... • Answered on Jul 31, 2014
Camedia e20 problems
Put memory card into camera right way around.
7/5/2014 6:38:40 PM • Olympus Camedia... • Answered on Jul 05, 2014
Camedia e20 wont record picture
Hi, any error messages?
6/20/2014 1:31:49 AM • Olympus Camedia... • Answered on Jun 20, 2014
0answers
Olympus Camedia C-460 Zoom del Sol Digital Camera Logo
11 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
trun flash off night
  • Cameras
