20 Most Recent
Olympus Camedia C-300 Zoom Digital Camera Questions & Answers
Cant get the pictured to download to Windows Vista
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Faulty memory card - card error.
hi,
May be, it is possible, but take a chance, try with another memory card, i hope you will get it from your friends. check the camera with that, if camera works properly means problem in your memory card.If camera not works means,there is something wrong in card accessing circuit of camera.
If so go to olympus shop.
also try to format your memory card with pc and then check the camera with that.
good luck
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set
Don't use barrettes from different sets or brands together.
I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away.
Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad.
Check you are using a charger for NiMH batteries.
I would try another set (new) because buying Alkaline is also not cheap.
I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
How to use zoom on c-860L
This 14 year old camera, does not have a zoom lens. It has a 5,5 mm lens, giving it a angle of view of about a 35 mm lens of a Full frame camera. However, you should be able to zoom digital 2 times.
I can't find a manual, to help you on this, but the quality will be the same as cropping into a frame on your computer. So if you do put the pictures on a computer, you also can "zoom" in to the parts you want. Be aware a 1 megapixel camera, does not offer that much of detail.
Manual setting of focus
Like many point&shoot cameras, the SZ-12 does not have manual focus. The closest you can come is to point the camera at the object your want in focus, press the shutter release button halfway, then frame the photo the way you want it and press the shutter release button the rest of the way.
Busy signal when I try to download photos
What model Olympus camera?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com).
Busy comes up when I try to download photos
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
