20 Most Recent E-Machines M5310 PC Notebook Questions & Answers
Could be the Ac -DC adapter is faulty .
Suggest taking laptop to where you bought it and asking if they can check it with a different Ac-DC power adapter .
E-Machines M5310... | Answered on Nov 08, 2017
This is something you no longer have to worry about. Vista is no longer being supported so Microsoft will no longer be releasing new updates.
Windows Vista Reaches End of Life Capital Support
E-Machines M5310... | Answered on May 06, 2017
HI,
I strongly suggest you to replace it with a new battery.
E-Machines M5310... | Answered on Dec 19, 2010
Try to perform power drain on the motherboard.
heres the steps:
take out the battery
unplug the power adapter
press and hold power button for 30secs
put the battery back in
plug in the power adapter
power on the computer
if same issue will happen then you need a battery replacement.
E-Machines M5310... | Answered on May 21, 2010
Use the information provided by Microsoft to help resolve this problem:
http://support.microsoft.com/kb/555531
If this does not work try to run CHKDSK /R from command prompt. You can do this with Windows Recovery Disk.
E-Machines M5310... | Answered on Dec 02, 2009
You may have a HDD thats developed some bad sectors or is going bad.
E-Machines M5310... | Answered on Jul 27, 2009
Go to the computer right on computer, click on properties, go to hardware, go to device manager, go to display, click on display, and delete, close out of all then reboot your computer, it should automatically see this problem and prompt for the correct driver(s), it may ask you for your OS disk.
If you cannot get it right. go to someone else's machine and go to www.driversguide.com, sign up and get the correct dirvers. then go back to the computer, it will prompt you for a driver. If you put the driver on a usb stick select the drive (say for example G) then click on the driver in the usb stick, this should work.
E-Machines M5310... | Answered on Jun 17, 2009
This may be a simple driver glitch with the modem. Uninstall the modem drivers from the device manager and reboot. The machine will find the modem and reinstall the drivers. If this doesn't work, then check for driver updates or any utility drivers from the support site for E-machines.
E-Machines M5310... | Answered on Aug 18, 2008
I just bought a lap top and no nothing about them it is a hp compaz nx 5000 I turned it on and the screen is still black don't know how and where to turn the monitor on
E-Machines M5310... | Answered on Jul 04, 2008
to boot a cd then you must have the bios set to allow it, or tap f12 immediately to intercept boot menu and choose cd. sounds like your drive has a few bad disk sectors.
E-Machines... | Answered on Jan 16, 2019
firstly lets think why a Working pc would no longer BOOT. The boot process then. a pc starts the bios which POST's. this results in ONE BEEP which might be followed by messages(if you get several beeps then they are like morse code long/short and count out an error code). when you get your ONE BEEP the pc is working. when it then HANGS(appears to do nothing) its usually because of either a) the cd drive is duff so disconnect its cables. b) the hard drive is duff so disconnect its cables c) the hard drive hasnt quite died yet but has some very slow sectors and is making the Clackety Clack of the heads recalibrating every few seconds. d) there could be a a gpu card bios glitch and your pc is running but you just have a blank screen. some hints then 1) never start removing parts as that corrupts the CMOS(the battery backed up configuration for your BIOS) so you may need to clear your cmos. 2) never play with the idea of changing ram sticks as people usually end up putting them in any old slot(which may result in a non working pc). make sure a PAIR is fitted in slots 0/2 and a separate matching pair in 1/3 slots not in slots 0/1 which is two half pairs. Other factors. 1) a short circuit. your PSU has built in protection, if the psu fan(inside case of the psu) turns and kicks back and immediately stops you have a short circuit and its cuts the power to avoid a fire/meltdown, which could be caused by high wattage gpu(>60 watts) without its extra power cables fitted or wrongly connected front usb cables or removing a mainboard and fitting it into a new box where the board has its support posts NOT lined up with the holes fro the screws so the post is touching underside of the board circuits. hope some of that helps.
E-Machines... | Answered on Nov 22, 2018
E-Machines M5310 PC Notebook Logo
Popular Tags
14 questions posted
Top E-Machines Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • E-Machines Computers & Internet
Most Popular Question
when turn nothing happens
  • Computers & Internet
