20 Most Recent Olympus Camedia C-3020 Zoom Digital Camera Questions & Answers
Pictures too dark - always underexposed
Hi David,Check out the manual linked here. Scroll down the document to the bottom of page 34. Locate the section called "Exposure Compensation" and make adjustments as needed. This should solve the problem & good luck!
9/4/2017 8:25:19 PM • Olympus Camedia... • Answered on Sep 04, 2017
Just got my olympus camedia c 3020 zoom camera on
it would appear that the camera is in playback mode. turn the dial to camera. another possibility is that the card is bad
12/23/2013 3:37:05 PM • Olympus Camedia... • Answered on Dec 23, 2013
I put a bad card in my camera without realizing it
One solution that has worked in the past is to clean the contacts in the camera. This can be done just by working the card in and out several times. Also take out the batteries and using cleaning alcohol on the card and working in and out of , but if you do this... allow the camera and card to air dry about 1 hour before using.
12/23/2013 3:13:52 PM • Olympus Camedia... • Answered on Dec 23, 2013
I bought my camera off ebay it's a great camera if
you will need a usb cord that connects camera to your pc. The computer will guide you to download.
8/13/2013 9:08:46 AM • Olympus Camedia... • Answered on Aug 13, 2013
When I bought the camera came with no manual and
You may download the manual for free from http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=720Consider getting a card reader instead of a cord. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
8/11/2013 1:17:00 AM • Olympus Camedia... • Answered on Aug 11, 2013
Is there a cord I need to get the pictures off my
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).You may download the C-3020 manual from http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=720
8/11/2013 1:05:10 AM • Olympus Camedia... • Answered on Aug 11, 2013
Camera will not power up after changing batteries
check the battery condition.
8/13/2012 11:22:31 AM • Olympus Camedia... • Answered on Aug 13, 2012
0answers
For several years my C-3020
In the camera menu, there should be a setting for "review" to allow you to set the number of seconds the picture remains on the screen. Also, you can always review the pictures you've taken by pressing the review button on the camera...it's usually a button with an arrow that points to the right.
1/21/2011 10:49:16 PM • Olympus Camedia... • Answered on Jan 21, 2011
My picture card is saying
Hi.
Check AE lock custom button:
Ensure that the memory card has no protective seal or object in front of the protection area. See here.
Ensure that the files are not individually protected (Key sign in settings)
If that does not fix the problem, then the card may be defective. In that case replace the card.
Here a manual.
9/14/2010 1:49:39 PM • Olympus Camedia... • Answered on Sep 14, 2010
I have an Olympus C-3020 zoom. I am trying to buy
  • Not aware of a 6v card this is old school technology and I thought they only made 3.3 and 5v cards to be comparable with PC voltage - this was the new floppy in the day.
  • A notched top corner on the left side, when facing the front of the card, indicates a 5 volt card. A notched top corner on the right side, when facing the front of the card, indicates a 3.3 volt card.
8/25/2010 11:06:19 PM • Olympus Camedia... • Answered on Aug 25, 2010
I need to download advanced manual for c3020
You can download the manuals from the manufacturer's web site at
6/16/2010 9:44:03 PM • Olympus Camedia... • Answered on Jun 16, 2010
Lost instruction and operation manuel
You can get manuals and much more from the manufacturer's web site at http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=720
4/30/2010 4:30:02 PM • Olympus Camedia... • Answered on Apr 30, 2010
Card cover error message
I didn't fix it, but I'm not willing to pay you for advice I can probably find free elsewhere.
11/28/2009 5:11:50 PM • Olympus Camedia... • Answered on Nov 28, 2009
2answers
3020 camera
Just hook it in and copy all pictures to a new folder on your desktop.
11/27/2009 9:26:54 PM • Olympus Camedia... • Answered on Nov 27, 2009
2answers
I lost the manuel and was looking for a site where
you can download it at any of these sites:
www.olympus.co.jp/en/support/imsg/.../download/software/
www.versiontracker.com/dyn/moreinfo/macosx/9428
download.cnet.com/Olympus-Camedia
7/5/2009 12:19:44 PM • Olympus Camedia... • Answered on Jul 05, 2009
Olympus Camedia C-3020 Zoom Digital Camera Logo
31 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
pictures dark always underexposed
  • Cameras
