20 Most Recent Olympus Camedia C-725 Digital Camera Questions & Answers
Special USB connection cord
Yes, the CB-USB4 cable that comes packaged with the camera; is required for downloading images using the camera. The stock number for a replacement cable is 200 776.
10/14/2020 4:16:47 PM • Olympus Camedia... • Answered on Oct 14, 2020
I have an olympus C-725 camera. i do not have an
You may download a copy of the manual at http://www.olympusamerica.com/files/oima_cckb/C725UZ-ENGLISH.pdf
11/25/2014 10:27:52 PM • Olympus Camedia... • Answered on Nov 25, 2014
2answers
Can I instal new software in this camera. Or
No, the firmware of the C-725 is not user-updatable.
12/23/2013 3:39:43 PM • Olympus Camedia... • Answered on Dec 23, 2013
How to reset
8/24/2013 6:53:38 PM • Olympus Camedia... • Answered on Aug 24, 2013
Write protect message
Check to see if your memory card isnt on lock....Take it out and theres a lock physically on the card
3/15/2012 1:58:41 AM • Olympus Camedia... • Answered on Mar 15, 2012
Ihave a olympus C-725.
Try the basic steps first by removing the battery pack and the memory card for a few seconds. Then, replace them back and check if that will fix the issue. If not, copy all the pictures from your camera to your computer. Then, using your camera, format your memory card and check if that fixed the problem..
9/27/2011 2:50:17 AM • Olympus Camedia... • Answered on Sep 27, 2011
I need a users manuel,
You can download the PDF manual and/or order a printed manual from
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1118
8/18/2011 7:18:56 PM • Olympus Camedia... • Answered on Aug 18, 2011
How do I take close-up shots? I can't get the
On the back of the camera at the top are three buttons. The one in the middle controls the "macro" function which allows you to focus as close as 0.3 ft.
10/9/2010 11:51:12 PM • Olympus Camedia... • Answered on Oct 09, 2010
We have a C-725 Olympus. Flash shots inside are
Lower the "exposure compensation". Lower the ISO.
11/11/2009 5:29:04 AM • Olympus Camedia... • Answered on Nov 11, 2009
2answers
Won't power up
Have you tried cleaning the battery contacts inside the camera? The problem that you describe is frequently due to a corrosion buildup that prevents the full power of the batteries from flowing to the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. This cleaning clears the problem about 90% of the time, and I hope it works for you.
9/19/2009 2:50:49 PM • Olympus Camedia... • Answered on Sep 19, 2009
E12 &E13 ERROR CODES
Shutter flex bad/worked itself out.
Available as a whole Lens Block only.
3/20/2009 1:44:19 PM • Olympus Camedia... • Answered on Mar 20, 2009
Burst??
The camera does not have a burst mode unless what you are referring to is a sequential shooting mode which it does have. Page 72 of your advanced camera manual explains how to set that mode up and use it.
1/19/2009 1:38:16 PM • Olympus Camedia... • Answered on Jan 19, 2009
How do I set the
Set the mode dial to AUTO, then press
the POWER switch to turn on the
camera.
● Be sure to take off the lens cap before
you turn the camera on (P. 27).
2 Press OK button.
● The top menu is displayed.
3 Press the up arrow button to select the clock.
4 Press
to select the date format.
● Select any one of the following formats:
D-M-Y (Day/Month/Year)
M-D-Y (Month/Day/Year)
Y-M-D (Year/Month/Day)
● This step and the following steps show the
procedure used when the date and time
settings are set to Y-M-D.
Press right arrow button move to the year (Y) setting.
6 Press
up or down arrow to set the year. When the year is set, press right arrow to move to the month (M) setting.
● Repeat this procedure until the date and time are completely set.
● To move back to the previous setting, press left arrow.
7 PressOk .
● For a more accurate setting, don't press until the clock hits 00 seconds. The
clock starts when you press the button.
8 To turn the camera off, press the POWER switch.
● The lens retracts.
1/13/2009 3:44:42 PM • Olympus Camedia... • Answered on Jan 13, 2009
Setting a timer
Refer to page 71 of the user manual:
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c725uz_e.pdf
It describes in detail how to use the self timer
1/6/2009 3:56:30 AM • Olympus Camedia... • Answered on Jan 06, 2009
Turning off sound recording on Olympus miu725SW
Unfortunately there is no way to disable the microphone when recording short movie clips. There is no menu setting to allow you to turn the microphone off.
12/11/2008 4:14:08 PM • Olympus Camedia... • Answered on Dec 11, 2008
Red dye reduction
You can find your manual here....www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c725uz_e.pdf
You find how to disable red eye function on page no: 63 in that manual.
For quick reference i am giving the details briefly,
The flash modes are as follows:
AUTO FLASH:
Automatically fires in low-light and backlight conditions.
RED EYE REDUCTION FLASH:
This mode significantly reduces
the phenomenon of “red-eye”
by emitting about 10 preflashes
before firing the regular
flash. This mode works the
same as the auto-flash except
for the pre-flashes.
To change between flash modes:
1 Press the (flash) switch.
● The flash pops up.
2 Press the / (flash mode) button
repeatedly until the desired flash mode
indication appears.
● The flash mode changes ,
● If / is not pressed within 2 seconds after the selection screen is
displayed, the selection screen disappears.
● To de-activate the flash (Flash Off mode ), push the flash back into the
camera.
3 Press the shutter button halfway.
● When the flash is ready to fire, the
(flash stand-by) mark lights.
4 Press the shutter button all the way.
● The flash fires.
Hope my info solves your problem,
Thanx for using fixya,
Good Luck.
9/30/2008 8:39:48 AM • Olympus Camedia... • Answered on Sep 30, 2008
Camera Turns off and flashes light soon after turning on then freezes
I have exactly the same problem and I found, that it is probably related to rechargable batteries. If I use normal batteries, everything works fine. Confusing is, that I used to use rechargable ones all the time, but errors started few days ago. I also have two sets of rechargable batteries, but both are useless now. Maybe that camera is getting old and it needs fresh 4x1,5V from normal batteries instead of 4x1,2V from rechargable ones.
11/21/2007 9:39:54 PM • Olympus Camedia... • Answered on Nov 21, 2007
Battery Empty
the little icon battery looks empty on the lcd screen? I would not worry about especially if your camera is taking flash pictures and lasting a good while....for my battery indicator on my two different cameras looks half charged and they high amp 2700ma. maybe its going over the mark. try putting in common batteries like duracell and see if it dont return to full indication charge.
8/31/2007 6:48:03 PM • Olympus Camedia... • Answered on Aug 31, 2007
Problems with new olympus 725 sw
I digicam that is Waterproof???? Don't believe that - unless it is in a housing. I suggest you dump this camera and get another and do not get it wet Wet and cameras don't mix This review does not mention a waterproof feature. http://www.digicamreview.co.uk/olympus_camedia_c725_review.htm
8/12/2007 1:08:37 PM • Olympus Camedia... • Answered on Aug 12, 2007
Olympus Camedia C-725 Digital Camera Logo
35 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
instal new software in camera or
  • Cameras
