20 Most Recent
Philips CCB130AT 13 in. Combo Questions & Answers
Although tv is showing picture the colours only
Hello
Your TVs red colour output section has the trouble. There is no red output at the red cathode of the picture tube. The red, green, and blue output sections are on the picture tube base board. In some Philips model, these will be consists of transistors, and some has an IC or Tree ICs for three colour output used. You just open your TV, measure the voltages at these three cahodes. There will be markings on the printed circuit board for these cathodes marked as [Rk,Bk and Gk].
In your TVs case the voltage at the Rk marked pin will be higher that the other two cathodes. This can be caused by an open drive transistor or an Ic whichever may ysed there. If it is transistor, just replace it with a same type and number, as in the ace of ICs the related Ic, must be replaced. If only one Ic is uded for red, green and blue outputs, that Ic must be replaced.
If you need any more assistance, feel free to get me through Fixya. Ok.
Philips CCB130AT02
Likely the tape sensor switch is faulty. Normally it is located on beneath the mechanism towards the front where the tape goes in. It is a micro-switch that is actually soldered to the main PCB. You have to remove the main board and desolder the switch. You might want to try replacing the switch since with over usage (tape in/out countless times) it may have worn out.
Note that VCR servos are such that if an event in the mechanism does not occur within a given frame of time the unit will shut down.
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
Philips tv Model - 21PT3525/V7 I want EHT Number ?
The EHT number for a Philips TV model 21PT3525/V7 can vary depending on the specific version of the TV. However, the EHT number for this model is typically BSC25-0235 or BSC25-0217.
It's important to note that replacing the EHT can be a dangerous process, as it involves working with high voltage components. If you're not experienced with electronics repair, it's recommended to seek assistance from a qualified technician who can perform the repair safely and properly.
3/4/2023 1:03:43 AM •
Philips...
Answered
on Mar 04, 2023
