20 Most Recent Olympus D-545 Zoom Digital Camera Questions & Answers
My camera keeps saying battery empty so I cant use it despite several sets of new batterises
RCR-V3 not as good as Nimh---->http://www.wrotniak.net/photo/c/rcr-v3.html. 1.5 and 3V Li even if rechargeble are not worth it. Look at your cell phone batterie says it 3.6 3.7V? Even your Smartphone with glued in Batteries has that. Check out if there are 3.6 to 3.7v Accus for your cam, if so you can use 18650 cells from an old laptop batterrie(if you want to ask me again). I will try this on my qld md 41066 cam too which quitted also very fast on premium brand Nimh(2xAA), this18650 are for free. Here in Germany we have extra recycling bins for poisonous/dangerus batteries in every supermarket.
8/7/2014 12:21:21 AM • Olympus D-545... • Answered on Aug 07, 2014
Lost CD for olympus D-545
You don't need the Olympus software in order to use this camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
7/7/2012 5:55:36 PM • Olympus D-545... • Answered on Jul 07, 2012
How do i set the date and time on my olympus
Turn the mode dial to Auto and press the OK/MENU button. Select [Setup] and then the one-handed clock.
It's all in the "Setting Date and Time" section of the Advanced Manual (page 75 in my copy).
3/21/2011 8:51:32 PM • Olympus D-545... • Answered on Mar 21, 2011
COMING ON BUT SWITCHING OFF WITHIN SECONDS EVEN
You may check whether your lens is popped out or not. If your lens is keep popped out then there are chances that your Shuttle is locked inside the camera.
Solution is need to replace the Shuttle, and it may possible that you gently (accidentaly) pushed/press the lens.
Regards Rushi
10/29/2010 7:13:31 AM • Olympus D-545... • Answered on Oct 29, 2010
I have just given my D 545 Zoom to my grandparents
You can download free ones, and/or order printed ones from the manufacturer's web site at http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1161
3/9/2010 5:21:20 PM • Olympus D-545... • Answered on Mar 09, 2010
When i try to power the camera on, the red light
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
1/6/2010 2:27:16 PM • Olympus D-545... • Answered on Jan 06, 2010
I have an Olympus D-545. For about the 4th time
It may be advisable to buy another card and try it to see what happens. Problems can occur on these cards. I have had some which quit working correctly. It is my advice to buy a good brand of card.
Since the camera is asking to format the card, do that, and then test it. Make sure you are testing and not taking good pictures.
11/9/2009 3:35:29 PM • Olympus D-545... • Answered on Nov 09, 2009
2answers
Where do I find a download of the Master Software
www.user-guides.co.uk/.../Olympus/OlympusD/Olympus-D-545-ZOOM-XP-Driver-CD-Recovery-Restore-Disk-243858.html
or
www.olympusamerica.com/.../cpg_archiv
ed_product_details.asp?...
Just copy and paste either link in your internet address bar under a new tab to bring you to software site
Feel free to ask any further questions
10/11/2009 10:13:19 PM • Olympus D-545... • Answered on Oct 11, 2009
3answers
Hi My Dad is having
The OLYMPUS Master folder is located inside your "My Pictures" folder.
To transfer a copy of the content of Master Folder into my picture you can do the following:
  1. Open My Pictures.
  2. Locate the Olimpus master folder.
  3. Open Master folder.
  4. When master folder is open, chose Edit>Select All from top menu bar, or click right mouse button and chose Select All.
  5. While all files into master folder are hilighted and selected (marked in blue, chose Copy, either from top bar menu, or using right button of mouse to recall the dropdown menu.
  6. Go to My picture.
  7. Chose Paste from top bar, or using mouse right button menu.
  8. A copy of the whole content of Olimpus Master Folder will be created into My Pictures.
In the future your Dad can also try setting the Olimpus software (Picasa) to use the My Picture folder as master folder, even if it is better to keep the two folder with different paths.
If software is Picasa, the option is on Settings command on top bar menu.
9/13/2009 9:19:26 PM • Olympus D-545... • Answered on Sep 13, 2009
Olympus D-545 won't change settings.
Rotate the dial around a few times to refresh the contacts.
5/3/2009 6:27:00 AM • Olympus D-545... • Answered on May 03, 2009
Erasing the memory card;
All pictures in the internal memory and/or on the memory card can be erased at once. This is accomplished through either formatting or the "all-frame erase" function. I copied the following instructions from the advanced manual, which can be downloaded here: http://www.olympusamerica.com/files/d545zadvman.pdf. Adobe reader should open that file with no problem. If it doesn't, that's another issue altogether.
1. Enter playback mode by pressing the play button.
2. Press the OK MENU button.
3. Press the right arrow button (next to the lightning bolt) to access [MODE MENU]
4. Then, press the down arrow to access the [MEMORY(CARD)] tab.
5. Select the [ALL ERASE] function.
6. Select Yes and press OK MENU.
(You'll need to use the arrow buttons to navigate the menus. Please see pg 16 of the manual for instructions on how to do so.)
Note: when the memory card is in the camera, it will erase the pictures off the card. When the card is removed, the function above will erase the internal memory.
4/22/2009 3:51:26 PM • Olympus D-545... • Answered on Apr 22, 2009
Card error
Use a card reader connected to a PC to backup your photos and then reformat the memory card.
4/9/2008 12:44:21 AM • Olympus D-545... • Answered on Apr 09, 2008
Download images to view the computer
With the camera turned off, connect the USB cable to the PC and plug the smaller end into the camera. The camera will turn on and display the selection screen for USB. Use the arrow keys to select the PC option and then press the OK button. The camera will be recognized by the computer as a removable drive. There are instructions available at our web site (http://www.olympusamerica.com/download). For editing and managing image files with a PC, install the Olympus Master 1.0 software from the supplied CD-ROM. After installing the software, connect your camera to the PC via the USB cable provided.
7/20/2007 1:46:47 AM • Olympus D-545... • Answered on Jul 20, 2007
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's menu and select OK to activate it. Once Pixel Mapping is completed the Menu displays. The bright dot should no longer appear in your downloaded images.
8/31/2005 1:55:48 PM • Olympus D-545... • Answered on Aug 31, 2005
Shooting features
There is an option where you can set the camera to capture two images side by side, within the same frame. This feature is called “2 in 1” and can be accessed through the Mode Menu. Press the OK/Menu button, and use the right (>) arrow key to access the Mode Menu. Press the up (^) or down (v) arrow key to navigate to the CAMERA tab and then use the right (>) arrow key to access this sub-menu. Use the down (v) arrow key to navigate to the “2 in 1” feature and by using the right (>) arrow hey the “2 in 1” feature will be active for the next two shots. After the second shot the camera will display the menu option for “2 in 1”. You can select the option again, or you can return to normal shooting by pressing the OK/Menu button.
8/31/2005 1:54:46 PM • Olympus D-545... • Answered on Aug 31, 2005
A/C adapter
There is an A/C adapter which is recommended for use with the D-545 Zoom Camera. The model is E-7AU. Use this 110V/120V AC Adapter to conserve batteries when downloading to your computer, for extended work in a studio, during printing, or while viewing images while connected to your TV or VCR. You can purchase this through the Olympus Emporium at https://emporium.olympus.com/ or 1-800-201-7766. The Olympus stock number is 200751.
8/31/2005 1:54:00 PM • Olympus D-545... • Answered on Aug 31, 2005
Telephoto images
The D-545 Zoom camera has a 3x optical zoom coupled with a 4x “seamless” digital zoom to deliver a total 12x zooming feature. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
8/31/2005 1:53:29 PM • Olympus D-545... • Answered on Aug 31, 2005
Settings affected
The functions available from the arrow pad, which are Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (arrow up key), Macro and Super Macro Modes for close up photos (arrow right key) will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ, but settings such as the language, the date and time, sleep time settings are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
8/31/2005 1:52:50 PM • Olympus D-545... • Answered on Aug 31, 2005
Olympus D-545 Zoom Digital Camera Logo
28 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Olympus Cameras
  • Olympus Cameras
Most Popular Question
when try power camera red light
  • Cameras
