20 Most Recent Olympus D-535 Zoom / C370 Zoom Digital Camera Questions & Answers
5answers
Olympus C-370 LENS GOES OUT, IN AND SHUTS OFF
It is possible that a flexible circuit connector has loosened. This can be checked by removing the covers, DISCHARGING THE CAPACITOR. (The large, black, cylinder beside the lens.) Remove the black Phillips screws holding the LCD and main circuit board and then carefully lifting the circuit and checking the large connector on the back of the main circuit. BE CAREFUL! It is easy to break the flex. The other, most likely cause is the failure of the Photo Interrupter in the lens. The only solution is to replace the lens and reprogram the camera.
8/29/2021 9:50:00 PM • Olympus D-535... • Answered on Aug 29, 2021
Need cd-rom to down load photoes to computer
You can buy the Cd from Olympus on their website, but you should be able to import the files directly from your camera using the USB cable, using it just like an external drive. If you are using a memory card for storage, you can also use a card reader to import your files. The free Picasa software from Google will import images and also allow you to edit them.
3/10/2015 6:37:56 PM • Olympus D-535... • Answered on Mar 10, 2015
Lost cd-rom disc for olympus C370 zoom digital camera
You don't need any special software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa: Organize edit and share your photos
11/15/2014 10:45:38 AM • Olympus D-535... • Answered on Nov 15, 2014
Olympus orporation digital camera c370 zoom
Do you really want a driver? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
5/3/2014 12:59:46 PM • Olympus D-535... • Answered on May 03, 2014
I need a cd rom for olympus c 370 camedia
You can donwload the needed drivers, firmware, photo viewer softwares from the official Olympus website: http://www.olympus.co.jp/en/support/imsg/digicamera/download/software/
3/9/2014 10:55:08 AM • Olympus D-535... • Answered on Mar 09, 2014
How do I take a video using this camera?
See "Recording Movies" on page 25 of the Basic Manual http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1135
7/5/2013 11:09:52 PM • Olympus D-535... • Answered on Jul 05, 2013
Not able o download photo to pc
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
10/30/2012 9:12:26 PM • Olympus D-535... • Answered on Oct 30, 2012
2answers
Battery /card door for my olympus d535
the part you are looking for is not selling separately.Your best bet is to keep the battery compartment door in place with scotch tape or other strong tape after you insert new batteries and look on ebay or craigs list for a similar camera which is defective and they are selling it for parts.You should be able to find one within a month or I can look for one for you and email you withe the link.just let me know
7/14/2012 8:36:18 PM • Olympus D-535... • Answered on Jul 14, 2012
Olympus D535 wont download on
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery.
10/18/2011 4:36:09 PM • Olympus D-535... • Answered on Oct 18, 2011
Olympus Camedia D-535 lens wont
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
8/31/2011 7:46:29 PM • Olympus D-535... • Answered on Aug 31, 2011
Up to how many gb memory card can i put on this
The specs for this camera say it uses an xD-Picture card from 16 to 512 MB. That's Megabytes.
Here is the main support page for your camera with links to manuals and other downloads.
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1135
Thanks for using Fixya.
5/21/2011 4:04:21 AM • Olympus D-535... • Answered on May 21, 2011
How to I delete all photos on this camera at the
Make sure you have a copy of the pictures you want to keep in your hard disk. Then just use the format memory card option of your camera.
5/17/2011 12:05:30 PM • Olympus D-535... • Answered on May 17, 2011
Camera wil not switch on. batteries
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
4/29/2011 11:45:07 PM • Olympus D-535... • Answered on Apr 29, 2011
How do i connect to my laptop
Please install first the D-535 driver on your laptop, then paired them using firewire / USB. Now your you can communicate them easily.
4/27/2011 12:14:50 PM • Olympus D-535... • Answered on Apr 27, 2011
Free download for driver
Consider NOT using a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
4/15/2011 5:14:40 PM • Olympus D-535... • Answered on Apr 15, 2011
I have windows 7 home premium. after loading the
Consider NOT connecting your camera to your computer.
4/6/2011 8:57:06 PM • Olympus D-535... • Answered on Apr 06, 2011
Olympus D-535 Zoom / C370 Zoom Digital Camera Logo
96 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Olympus Cameras
  • Olympus Cameras
Most Popular Question
need cd rom olympus c 370 camedia
  • Cameras
