20 Most Recent
Olympus Camedia C-60 Zoom Digital Camera Questions & Answers
How to update my camera to 2Gb memory
Olympus say the C-60 Zoom is not compatible with the 2GB xd card. Standard cards upto 512MB appear to be available online but not in high street stores.
How do I upload pics to computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
How can i find C-60 driver?
Do you really need a driver?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
My Olympus Camedia C-60 Zoom Camera has served me
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Hello, I have 2 questions.
Put camera in P/A/S/M setting on dial, then > Mode Menu,then arrow down to "Set Up", then right > to ALL RESET, toggle to Off. Done
Camera will not close error 1e1a
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
Dont know which memory card my olympus c-2 zoom
I am not sure about the model number you have mentioned, Visit
olympus site to see the compatibility of memory card. You can also visit this link to see the camera
xD picture card compatibility for
C-series.
Good luck & have a nice day
Rating the solution is highly appreciated.
?1.8" Semi-transmissive (low-reflective) TFT color
The LCD brightness control in the menu can be adjusted too low, or it could be that the backlight in the LCD screen assembly is failing. Try adjusting your settings, and if that doesn't work, try resetting the ribbon connector to the backlight (it should be the smaller ribbon cable). If that doesn't work, the whole LCD screen will have to be replaced. You can find them on Ebay sometimes fairly cheap, if you do it yourself. There are videos on YouTube that show the general process, but it's not hard. Get an estimate first if you have a repair shop fix it, since it can cost more than a new camera.
Good luck, thanks for using FixYa, and hope this helps.
INFECTED DIGITAL CAMERA WITH FU VIRUS
The best way to remove virus from your computer is :-
Step 1. Download free version of Malewarebytes AND superantispyware from http://www.itechguru.in/Download%20Links/Download%20Links.htm
Step 2 . Install it and update it from update tag >> check for updates.
Step 3. After that go to tag scanner and perform full scan.
Step 4. When scan complete click on show result and then click on remove selected.
Step 5. After removal it will ask you to restart your computer. Restart once.
And enjoy Virus/Spyware free environment.
iTechGuru
www.iTechGuru.in
The zoom stopped working, doesn't
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, chances
are that your batteries need to be replaced because they're just too worn to properly power the camera.
And then, of course, there's the possibility that your camera may have
a problem that requires professional repair.
D: 1E11
The problem you are describing is a problem with one of the sensors in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $125 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
