20 Most Recent Philips 60P8341 60" Rear Projection Television Questions & Answers
My Philips Magnavox 60 in rear projection TV # PTV775-AH01 has no power when you turn it on. How can I fix it?
It sounds like a power supply problem, it could be as simple as an internal fuse (not the fuse in the plug) or something more sinister like a transformer issue which can become expensive, either way i wouldnt recommend repairing yourself unless your confident with electrics and know what to look for
10/28/2014 4:24:47 PM • Philips 60P8341... • Answered on Oct 28, 2014
0answers
Unpluged the projection tv put in truck and moved it down the road pluged it n and doesnt work
Check first for loose cables...that is a common issue when the tv sets are moved.
4/19/2013 6:46:17 PM • Philips 60P8341... • Answered on Apr 19, 2013
Changed crt fluid in my 60 in. philipps projection tv.(60pw38317f) did all steps..everything pluged in.. but now there are lines on my screen...did i miss something???
If the lines are straight you likely over adjusted the brightness knobs...or you have a loose cable...if the lines are warped you need to adjust the convergence. If the convergenec wont adjust it needs to be repaired. Sites such as www.TvRepairKits.com have both kits,
4/10/2013 6:12:37 PM • Philips 60P8341... • Answered on Apr 10, 2013
Changed crt coolant, better picture. red squiggily line starting at top center of screen, runs about a third of the way down. thought i saw scratch or small crack in green crt "c" lens. would this cau
Sounds like you may have just left one of the wires loose from the red tube. Not likely an issue from the gren tube but you can always cover the top of the lens and let just green shine up. That may help narrow it down also. Here is more detailed info for you also.....Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images. Picture of a set that needs the fluid changed.578ba6c.jpg TV set after fluid change65af323.jpg 69189a5.pngSOLUTIONWhat you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
1/31/2013 6:20:36 AM • Philips 60P8341... • Answered on Jan 31, 2013
Shows speaker emblem tnen picture goes out then 2 minutes comes on
You may have the small signal module in the set bad
12/22/2012 12:57:52 AM • Philips 60P8341... • Answered on Dec 22, 2012
Wont power on
does any power indicator? if none check for a blown fuse first at the power supply board.
10/11/2012 9:47:30 AM • Philips 60P8341... • Answered on Oct 11, 2012
2answers
Philips nr.43pp7445/69
I don't understand you language but I think you need both convergence amplifier IC's replaced. I hope this helps.
10/8/2012 8:48:42 PM • Philips 60P8341... • Answered on Oct 08, 2012
I have sound but no picture
Not a good set repair wise-------I would say replace rather than repair.
9/3/2012 2:55:19 PM • Philips 60P8341... • Answered on Sep 03, 2012
How do you change the fuse on philips 60p8341a
The set has more than one---main power fuse is directly inside the set where the power cord goes.If it is good provide a more detailed explanation of what set is doing.
8/30/2012 3:02:34 PM • Philips 60P8341... • Answered on Aug 30, 2012
60p8341 fuses
TRY MCM ELECTRONIC OR ANY ELECTRONIC PARTS STORE IN YOU AREA JUST TAKE THE FUSE WITH YOU
4/27/2012 11:09:39 PM • Philips 60P8341... • Answered on Apr 27, 2012
2answers
I have a Phillips rear proj. 60pp9202/17f with a color problem
3_24_2012_6_00_06_am.jpg This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
3/25/2012 5:34:10 AM • Philips 60P8341... • Answered on Mar 25, 2012
Need the flyback for the 60p8341
part # 312226832861, or sub 312226832865good luck
11/26/2011 8:15:41 PM • Philips 60P8341... • Answered on Nov 26, 2011
P50pdtv10a will not change channels stuck on channel 3
HelloThe system memory IC of your TV has damaged. This is one, which stores all the setting we have done with remote control, including channel memmory. This IC works in conjunction with the main system control IC. When we switch OFF or do any other adjustments with the tV, all the data will be stored in this IC, and tetreived from it to main system IC to process when we switch ON the TV. This is a non-volatile memory chip, ie, even the power is OFF, the data stored in it won't lost. This is a very small IC, can locate very near to main system control IC. Will have 8 solder terminals [normally], and ver cheap to buy too. Even though it is a very cheap and small one, the function of it in the circuit is great. In some Vizio sets, this IC will be of SMD [surface Mount Device] type, and on othere will be a DIL [Dual In Line] type pin confujuration. If your TVs memory is of first as stated above [SMD], replacing it will not be an easy job. If it is of second type, it can be replace easly.Anyway, this is not a work that can be done without skill. If you have enough knldege in electronics, and have a concept of desoldering and soldering, have all soldering equipments with you, you can do this work by yourself at home. Otherwise you have to seek assistance from an experienced service technician. OK.gopakumarg43
10/20/2011 4:15:23 PM • Philips 60P8341... • Answered on Oct 20, 2011
I need a switch board
No sure which board your refering too? Is it the front panel board with the power button and controls?
7/19/2011 8:27:51 AM • Philips 60P8341... • Answered on Jul 19, 2011
Philips 60P8341 60" Rear Projection Television Logo
Popular Tags
180 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
changed crt coolant better picture red
  • Televison & Video
