20 Most Recent
Polaroid PhotoMax PDC 1300 Digital Camera Questions & Answers
How to transfer my pictures that i just took off m...
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Once the pictures are on your computer, you can treat them as you do any other file. Obviously, the procedure for inserting a picture into a document depends on the program you're using to create/manipulate the document.
4/11/2011 4:53:36 PM •
Polaroid...
Answered
on Apr 11, 2011
ERROR: code 28 -- Windows XP & USB 2.0
This message appears because Windows XP did not originally support the USB 2.0 specification.
However, as of May 2002, the final release version of the Microsoft USB 2.0 drivers for Windows XP is available at the Windows Update Site. The driver is designated Microsoft USB Driver Version 5.1.2600.0.
9/21/2005 3:28:52 PM •
Polaroid...
Answered
on Sep 21, 2005
USB connection problem using Windows 98 Second Edition.
The cause of this problem can be traced to both the computer's hardware configuration and Windows 98SE (Second Edition).
PhotoMAX cameras and other devices featuring USB (Universal Serial Bus) connections may not work with computers running Windows 98 Second Edition and equipped with the following computer hardware:
* an AMD processor (350 MHz or higher)
* VIA Technologies USB Host Controller or SiS 7001 USB Host Controller
To find out what USB Host Controller is on your system:
1. Click Start > Settings and choose Control Panel.
2. Double click the System icon.
3. Choose the Device Manager tab. A window similar to the one shown below appears.
4. Expand the Universal Serial Bus controllers listing by clicking on the "+" sign next to the listing.
5. Note the type of host controller in the listing. The example above shows the SiS 7001 PCI to USB Open Host Controller.
9/14/2005 1:38:29 PM •
Polaroid...
Answered
on Sep 14, 2005
Green light flashing on Polaroid iE 6035
The green light flashing on your Polaroid iE 6035 camera typically indicates that the camera is in standby mode or that it is charging. If the camera is not charging, it could be a sign of a problem with the battery or charging mechanism. If the green light continues to flash even after charging, it may be necessary to take the camera to a professional for repair or to have the battery replaced. Before seeking professional help, you can also try resetting the camera or removing and reinserting the battery to see if that resolves the issue.
